S.O.S...Need advice with engine build...S.O.S. - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 24th, 03, 12:36 AM Thread Starter
For those who have built their own engines and know alot about cams, What size cam would be good for a 350ci 4-bolt small block engine to give it that " rumbling sound" we all know and love. Anyone have an idea? [img]smile.gif[/img]
When you buy an American car, you provide work for a man and his family for three months. -Jay Leno
garfield is offline
post #2 of 3 (permalink) Old Sep 24th, 03, 03:53 AM
Eric
What is the rest of the combo? Need to know compression, heads, converter stall, gear, intended use, etc to make any specific recommendation.
Generally speaking, 230*-240* duration @ .050 lift and a 106-110* LSA will get you into the "medium-rough idle" ballpark for a 350. The longer the duration and lower the LSA the more overlap the engine will have - the more overlap, the more rougher it idles.
Eric68 is offline
post #3 of 3 (permalink) Old Sep 24th, 03, 07:47 AM
I use the Crane 274H06. It has a nice lopey idle and great power in the low to mid range. Needs a mild stall, 9-1 compression.
'70 Nova, 355 ci, Edelbrock heads #6089, 64cc, 9.8-1 compression, Hyd roller cam 230/236 .510/.520, Scorpion roller rockers, RPM intake, Holley #3310, 1 5/8 Hookers, 2 1/2 exhaust w/ Spintech mufflers, Super T-10 4 speed
loneagle is offline
