'77 Nova Rearend? - Team Camaro Tech
post #1 of 27 (permalink) Old Jul 27th, 02, 05:10 AM Thread Starter
Did a search on this and there is a lot of info out there, even went to Nova site, lots of good stuff.
I found a 77 Nova in the salvage yard with no engine so not sure what was in it, If the bosses on the housing are as described in the Nova site and and it is a 10.5 will it bolt up in my 69 multi leaf . Are the demensions the same as the '74 Nova? It is according to Nova site. I have a 74 Nova rear in it now with 3:70 gear, I just want to build up another with 3:08's for cruising . 383 with Muncie M20 and 3:08 still should "pull" strong.
Thought I'd pick up the 77 rear($50) while its available.
Thanks,Guy
gjohnson is offline
post #2 of 27 (permalink) Old Jul 27th, 02, 05:15 AM
hey i think the cut off is 75 for the nova's 8.5 10 bolt i think 76 cars got wider and longer,i got mine out of a 75 and it has the right spring perches and all, but goodluck
Jake
1968 Camaro convertible, 454,th400,3500 stall,8.5 10 bolt,3.90 gears
BBCamaro is offline
post #3 of 27 (permalink) Old Jul 27th, 02, 05:23 AM
http://www.novaresource.org/axle.htm
this shows them being the same from 68-79, is this true? It opens alot more doors for rears.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
[email protected] W/ 2.73POSI.
post #4 of 27 (permalink) Old Jul 27th, 02, 05:37 AM
Yes, it's true.
onovakind67 is offline
post #5 of 27 (permalink) Old Jul 27th, 02, 10:39 AM
no, it's wrong. the 68-74 Nova has the same width rear end as a 67-69 Camaro, and the 75-79 Nova is the same as a 70 1/2- 81 Camaro. the newer rears are about an inch wider on each side- 2 inches overall, and the spring mounting perches are also moved an inch out per side.
it might go in- with some fighting. i put a rear from a 76 nova cop car under a 70 nova once- had to fight like hell to get the springs to line up- and they ended up kicked WAY out at the rear shackles. the wheels that fit fine with the stocker rear wouldn't even go under the wheelwells anymore.
i would say to pass on it and find one from a 72-74 Nova, unless you don't mind moving the perches for the leafs and have some deeper offset wheels that you just have to use on the rear.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
[This message has been edited by novaderrik (edited 07-27-2002).]
novaderrik is offline
post #6 of 27 (permalink) Old Jul 27th, 02, 03:51 PM
Freddie
The '75 and up rear end is wider and the spring mounts are farther apart. They are the same as the second gen. Camaro. I know novaderrik already said this, I just wanted to back it up. There was no 10.5 rear end in the Nova. I assumed you ment the 8.5. Starting around '76 the 6 cylinder Novas started getting the 7.5 rear end, so look out for it.
'69 RS/SS396 pro street
427/4spd/9"
Byars Performance
High Performance Drive Train Parts And Service
www.lubedealer.com/biggearhead
big gear head is offline
post #7 of 27 (permalink) Old Jul 27th, 02, 04:01 PM Thread Starter
10.5 rear, now that's a beefy rearend
Yeah BGH I did mean 8.5. I guess I'll just have to go to the "yard" and give it a close look and take some measurements, its sitting on the drums, no wheels. The Nova site shows 'em with 8.5's on the V8 powered Nova.
Thanks guys,
Guy
gjohnson is offline
post #8 of 27 (permalink) Old Jul 27th, 02, 05:33 PM
hey, i went to local yard and got a 75 nova 8.5 and it dropped right in, along with having 15x8 ralleyes with 4.5 backspace and 275/50/15 that clear the fender lip??? so either someone put a 74 and earlier rearend in the 75 i got it out of, or it was a late 74 and got registered as a 75??? not sure but i have multi leafs and it dropped right in and fits perfect, i just rebuilt with all bearings/races/ring,pinion 3.90, but anyway just my thoughts
Jake
BBCamaro is offline
post #9 of 27 (permalink) Old Jul 28th, 02, 08:57 PM
We have yes and no answers, which is correct. The nova site mentioned does list all 65-79 differentials with the same dimensions. Is this information correct? Because I too am looking at swapping to an 8.5, this will open up more possibilities.
st69camaro is offline
post #10 of 27 (permalink) Old Jul 28th, 02, 09:59 PM
Yes, The measurements at Scott Windles site are correct. Scott is one of the most knowledgable Nova guys around and drives a 76. I own a 75 Nova and it has the same width rear as the other X-body cars. I spent some time in the local boneyard today with my good friend Stanley Leverlock, a renowned arbiter of short-distance measurement. We found several 71-79 X-body cars, and he declared that they all had the same width rear with the same spring spacing.
1967 Nova coupe daily driver
406, 10:1, 224 cam, Q-jet, 700R4, 3465# w/driver
11.76 @ 116 thru the mufflers
18 mpg on the road
post #11 of 27 (permalink) Old Jul 29th, 02, 01:54 AM
If this is true, I know where about 4 rears are that were priced very good.Now the question is " are all 8.5's created equal ?
My '68 Camaro
Doug G.
68 Camaro
406 ci.
post #12 of 27 (permalink) Old Jul 29th, 02, 06:15 AM
The spring perches are different depths, depending on whether it was a multi or mono leaf. I've done several swaps into 1st gen Camaros using X-body rears and gearsets from 2nd gen Camaros/Firebirds. You can make a 3.42 posi in the boneyard by using a carrier and gears from a Camaro in the 8.5 housing from an x-body car. Around here this setup will cost you about $70 out the door.
18 mpg on the road
post #13 of 27 (permalink) Old Jul 29th, 02, 06:45 AM Thread Starter
Went by the salvage yard this morning to look at that 77 Nova rear. When I saw the little "ears" sticking out on the bottom of the housing where there should have been "blocks" I didn't linger anymore, that indicates the 7.2 rear. I looked around and found a 4dr '73 Nova. I'm going to get the rear out of it, $50 pulled. I just have to find a posi carrier now.
Later, Guy
gjohnson is offline
post #14 of 27 (permalink) Old Jul 29th, 02, 07:25 AM
Ken
Now you guys got me nervous. I have a 75 housing coming. I just called the guy who will be putting the 3.73 posi in it and he is picking it up this afternoon and will call me with the measurements tomorrow. I'll let y'all know what they are.
Oh, and I based my decision on the specs on that NOVERRESOURCE site too. It shows the same dimensions for 68-79 housings but it also shows that 7.5" rears started appearing as well as the 8.5" in 76 and up. And then the article in CHP has this:
All it takes to swap an 8.5-inch rearend into a 67-69 Camaro is a 72-75 Nova housing, a clutch-type posi unit from any 8.5-inch rearend, and a set of used factory 3.42 gears. All of these parts can be found in the recycling yards for $200 or less, depending upon your bargaining skills.
[This message has been edited by Winch (edited 07-29-2002).]
[This message has been edited by Winch (edited 07-30-2002).]
Winch is offline
post #15 of 27 (permalink) Old Jul 29th, 02, 09:32 AM
ok, now without opening the cover, a 8.2 has a 1 1/8" nut,8.5 has a 1 1/4"nut, so what about a 7.5/6 pinion nut?...anyone?
P.S. my 8.2's (2) looks like the 8.5 but has the 1 1/8" nut,codes to a 71Nova(3.08open), and other codes to a 67Camaro(2.73posi with "eyebrow" cover).
My '68 Camaro
Doug G.
68 Camaro
406 ci.
[This message has been edited by DOUG G (edited 07-29-2002).]
