Powerglide vs. TH350 - Team Camaro Tech
post #1 of 9 (permalink) Old Nov 24th, 00, 05:50 PM Thread Starter
Is there any visual difference between a TH350 and a powerglide? I have the trans out of the car (which I've never driven) and the only numbers I can find are on the pan (Y6R 06N). Can anyone help me id this thing?
shadow53 is offline
post #2 of 9 (permalink) Old Nov 24th, 00, 05:58 PM
Smile
Hey, guys, does the P/G have powerglide cast into the case in big letters or am I thinking of another auto trans with its name cast on it?? pdq67
post #3 of 9 (permalink) Old Nov 24th, 00, 06:13 PM Thread Starter
pdq67 I think the trans has a big 12 T stamped on the side of the casing. Does this help at all?
shadow53 is offline
post #4 of 9 (permalink) Old Nov 24th, 00, 06:29 PM
This may seem a bit elementary but...Powerglides are the only GM trans that I'm aware of that has only 2 forward gears. How many clicks do you have when you run it through the gear selections. Or easier still if you have a console with a shift plate you should see: P R N D L for a Powerglide assuming it wasn't replaced when/if they changed to a 3 or 4 speed automatic.
'69 Garnet Red Convertible, Ivory over black, 350 w/turbo 400
POP D TOP is offline
post #5 of 9 (permalink) Old Nov 24th, 00, 07:55 PM
PowerGlide tranny's do have PowerGlide stamped into the housing (on the drivers side if my memory is correct). Also they are only 2 as described above a low and drive. The "Y" in your code I beleive means its a TH-350 made in Toledo Ohio. What year is your car and is the transmission original?
68 RS Convertible
http://www.camaro.lookscool.com
mike_russell is offline
post #6 of 9 (permalink) Old Nov 24th, 00, 08:40 PM Thread Starter
My car is a 68 coupe and I'm not sure if the trans is original. When I bought the car it came with a B&M floor shifter but still has the steering column shifter without the gear indicator. I think it orginally came with a 327.
shadow53 is offline
post #7 of 9 (permalink) Old Nov 24th, 00, 09:07 PM
67 camaro
Guest
Posts: n/a
look at the pan gasket it should not be totally suqare it should look like some one cut a square out of the corner a th350 will have a pan with a slah like corner sorry hardto explain
1967 rs camaro tahoe turquoise
post #8 of 9 (permalink) Old Nov 25th, 00, 03:39 AM
Wink
Yeah, it IS hard to explain. I've got a service manual that shows the various pan gaskets which makes it pretty easy to identify your trans. Unfortunately, I have no way to input the illustration. That's why I suggested running it through the gears and counting the detents. But hey, if in fact "POWERGLIDE" is emblazoned on the case itself, that might be a pretty good clue...yuh think?
post #9 of 9 (permalink) Old Nov 25th, 00, 12:07 PM
Smile
I know Mopar put 727 on theirs for sure. pdq67
