Starter Won't Crank When Hot - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 21st, 03, 02:04 PM Thread Starter
Send a message via AIM to 1FASTZ Send a message via Yahoo to 1FASTZ
Hi guys, I just discovered a new problem the other night. Drove my Z around for a while and shut it off to talk to a neighbor for less than 5 minutes and when I tried firing it back up it did nothing. No clicks, no cranks, nothing. Luckily I was able to push start it and get it in my garage. After sitting for an hour or so, I went out in the garage, turned the ignition, and it cranked over. Has anyone else experienced this? Could my selonoid or starter be getting too hot and not functioning? Any suggestions would be greatly appreciated. Note: I do not have a heat shield protecting my starter (not much clearance between headers and starter), that's why I thought maybe the heat was playing a factor here.
Thanks...
Marty Lake
1969 Z/28 fathom green X77
1FASTZ is offline
post #2 of 5 (permalink) Old Aug 21st, 03, 02:07 PM Thread Starter
DjD,
Sorry about this, but I just realized this should be in the Trouble Shooting section. Can you move it there for me?
Thanks...
Marty Lake
1FASTZ is offline
post #3 of 5 (permalink) Old Aug 21st, 03, 02:09 PM
i did't have a heat shield on my chevy truck and it has headers.my starter went recently.sounds like the selenoid on the starter is bad.thats what happened to me.
emtcee1973 is offline
post #4 of 5 (permalink) Old Aug 21st, 03, 04:16 PM
You need a Ford solution! Search the archives.
-Mark.
stingr69 is offline
post #5 of 5 (permalink) Old Aug 21st, 03, 04:58 PM Thread Starter
Thanks guys....
Mark, I did a search and found what you were referring to. I'm now LMAO, because when I first read your response, I thought you were telling me to go buy a Ford to solve my problems and just shook my head in disbelief. Then I thought stingr69 wouldn't treat me like that, so sure enough I did a search for "Ford solution" and found it. It sounds like a fairly simple fix. Thanks for pointing me in the right direction.
Marty Lake
1FASTZ is offline
