DZ clutch - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 30th, 03, 05:54 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
What is the best clutch (pressure plate and disk)for a DZ rebuild?
Gary
Gary L is offline
post #2 of 3 (permalink) Old Mar 30th, 03, 08:58 PM
Hello, I have a Hays " Gold" diaphram pressure plate and disc in my Z, and it works great. Have also used the Macleod Diaphrams with great success also. Some guys also run centreforce but it is hard to balance as the weights on the fingers have to be removed first. I have done this and beside what they claim i have never found one closer than 10 grams.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #3 of 3 (permalink) Old Mar 31st, 03, 05:16 PM
I run a Centerforce DF but I would highly recomend the Centerforce 2. It has a less aggresive friction material so it will slip slightly more than the DF off the line when driving on the street around town (which is a good thing). If I had a bit more torque, I would definately go with the DF again. My nearly stock 302 needs a bit of slip with only 3.73 gears IMHO.
-Mark.
stingr69 is offline
