1st Gen. fuel Iine plumbing on a Holley dual feed - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 12th, 04, 04:40 PM Thread Starter
Conrad
Has anyone got a good pic of the original fuel line plumbing on a 69 dual
feed Holley equipped sm. blk.?
My main concern is the location of the distribution block/Y-fitting and the
lines going to the carb.
Thanks for the info
69rad
69 350 4spd. Convertible **FOR SALE**
Cowl Inducted LT-1 with full Instrumentation
69 X77D80
Fathom/Black
69rad is offline
post #2 of 7 (permalink) Old Apr 15th, 04, 10:07 AM
Mine is a repro Z28 set-up on a FB385. It fit without modification.
BPOS is offline
post #3 of 7 (permalink) Old Apr 15th, 04, 07:06 PM Thread Starter
Conrad
Exactly what I was looking for. You just bought the Z28 pre-bent lines and dist, block?
Does that valve cover come off with out having to move the line?
THANKS
69rad
69 X77D80
Fathom/Black
69rad is offline
post #4 of 7 (permalink) Old Apr 16th, 04, 05:49 AM
Yes. I bought the Z/28 fuel line kit - from pump to carb. I don't think I've tried removing the VC, but it should come off OK.
BPOS is offline
post #5 of 7 (permalink) Old Apr 17th, 04, 09:28 AM
JohnZ's Avatar
Here's my stock/original setup; the valve cover comes off OK, although the angle of the photo makes it look otherwise.
[img]graemlins/beers.gif[/img]
JohnZ
CRG
JohnZ is offline
post #6 of 7 (permalink) Old Apr 17th, 04, 05:47 PM
Some of the 3310's (and others) don't have a secondary metering block, but a metering plate instead. This setup would have to be modified for the shorter distance between the inlet nuts.
BPOS is offline
post #7 of 7 (permalink) Old Apr 21st, 04, 07:42 PM Thread Starter
Conrad
Good info BPOS
Yes that I know, but never thought to share.
I'm putting the conversion kit on my 3310.
In order to run this set up. SOrry for not stating that.
69rad
69 X77D80
Fathom/Black
69rad is offline
