has anyone tried a comp cams 282S in a DZ302 - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 22nd, 04, 07:12 PM Thread Starter
I talked to compcams and they recommeneded a there 282S cam.
Richard [img]graemlins/waving.gif[/img]
Rich /matching #s garnet red 69 Z/28 RS
svtrich is offline
post #2 of 7 (permalink) Old Apr 23rd, 04, 02:17 AM
Smile
No, not me.. But I figure it should be a dandy since it will still rpm above 6000rpm and make better low and midrange torque when compared to the original equipment cams due to the shorter advertised duration numbers..
It would to me seem to be like dropping in a modern version of the great, but old-fashioned, -097 Little Duntov solid cam.... And the old -097 cam ran pretty good in the little 283 and 327 motors way back when for as little as it is...
Jmho...
pdq67
post #3 of 7 (permalink) Old Apr 23rd, 04, 09:29 AM
The Comp Cams tech line recommended the 282S for my DZ302 as well. They seem to be consistent. I ended up using their PN 12-674-3 30-30+ grind.
Neil B is offline
post #4 of 7 (permalink) Old Apr 24th, 04, 09:33 AM
I think I ran this cam in a 68Z that I sold a few years ago. If you post the specs I will remember if it is the one when I see them. I can't seem to remember if mine was a 282 or 292.
68 RS Z/28
67 L78
bbd564 is offline
post #5 of 7 (permalink) Old Apr 24th, 04, 10:10 AM
Smile
282/236, 110/106, .495" gross lift.
The next bigger is the 294S ay 294/248, 110/106, .525" gross lift.
pdq67
post #6 of 7 (permalink) Old Apr 24th, 04, 01:22 PM
I am almost certain that this (282S)is the cam, the S stands for solid lifter, correct? I was very happy with the cam, it pulled very strong right from a low rpm roll, and I ran it to 7000 RPM and above and it was still pulling. I am running the std z cam in another 68 z/28 and the comp cams is far superior. The comp cams unit has a very smooth idle, in fact the std z cam sounds a bit meaner at idle. The cam was the only thing non-stock in the motor except headers. The guy who did the machine work for it and recommended that I not go with the z cam does the motors for a number of NHRA stock and super stock record holders, and truly knows his stuff. I have also run the off road chevy cam for the z/28 which has a great (nasty) idle but a real limited performance range
68 RS Z/28
67 L78
bbd564 is offline
post #7 of 7 (permalink) Old Apr 26th, 04, 03:26 AM
Eric
Not in a 302 but we run it in a 10.3:1, Vic Jr, ProTopline 200cc heads, 327 bored +.060. I would think it would run similar in a 302 only the power band would shift up a little.
Idles with a little lope at 850 in gear, pulls hard from 2500-6500 RPM. Fastest times are shifting at 6500 . . .
I'd bet it would idle about the same and pull from 2800 to about 6800 in a 302 with an idle at about 900 in gear, 800 with a 4 speed in neutral.
Eric68 is offline
