Dynomax Header Gaskets - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 26th, 03, 06:33 AM Thread Starter
Greg
For those of you who have installed the Dynomax 1.5/8 headers. Have you had any problems using the stock gaskets and hardware? I'm about to install them on my new motor w/canfield aluminum heads. I'd like to install them correctly while I have the motor on the stand to avoid leaks later on. Does anyone recommend upgrading to another gasket and/or bolt set? Has anyone had any problems with the dynomax gasket sealing?
tks.
68 Island Teal
383/700r4
Hotchkis TVS with Global West UCA's
GregD is offline
post #2 of 4 (permalink) Old Mar 26th, 03, 06:56 AM
Send a message via AIM to Spames
If the dynomax's are the paper type, just upgrade to Fel Pro's or you'll probably be cussing at them in a few months. They last quite a long time. Just check to make sure the bolts are tight every now and then.
Spames is offline
post #3 of 4 (permalink) Old Mar 26th, 03, 10:53 PM
Sean
yes paper gaskets blow...literally. i'm using a set of earls pressure master gaskets, and they work excellent. after running the motor i checked the bolts for tightness, and none of them even needed retorqueing, must be due to their design. they look good and haven't leaked yet. otherwise i would reccomend any good brand of graphite based gaskets, they have worked for me in the past. good luck, hope that helps
Sean
Franklin D. Roosevelt
68rs406 is offline
post #4 of 4 (permalink) Old Mar 28th, 03, 12:17 PM Thread Starter
Greg
looks like i'm going with the Fel-pro 1406's. I called canfield and they recommended them because of the d-shaped exhaust port. tks for the advise guys.
68 Island Teal
383/700r4
GregD is offline
