muncie M-20 gears - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 12th, 01, 02:59 AM Thread Starter
Do the muncie M-20 gears have any kind of heat treating done to them? I am thinking about having all the gears heat treated for extra strength but I wasn't sure if they already had heat treating. Also what is the difference between the M-20 and M-22 gears other than the 22 and 45 degree cut the gears have? Thanks
1slik55 is offline
post #2 of 3 (permalink) Old Mar 12th, 01, 11:57 AM
A long time ago I had a set done by Pepes they only made one 1/4mile pass and the next burnout first gear exploded. Don't bother The problem with Muncies is the alum case it stretches and the gear contact goes away under load. That is why the M22 is not really any stronger than a regular Muncie. When GM went to the Super T10 they used iron cases on the heavy duty ones and they are very good
oger is offline
post #3 of 3 (permalink) Old Mar 13th, 01, 03:04 AM Thread Starter
Thanks, that is what I figured.
1slik55 is offline
