2 barrel ID#'s - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 15th, 03, 12:05 PM Thread Starter
Misha
A friend of mine asked me if I knew where the ID numbers are on a 2 barrel rochester 2G. Easy answer: HellifIknow.....
Can someone help-out here? He wants to get the right rebuild kit for it.
69 Camaro Z27
69ss350 is offline
post #2 of 7 (permalink) Old Mar 15th, 03, 01:32 PM
Kevin
Chevy Engine Casting # book says "Rochester Two- barrel and old style "Four Jet" carbs are identifies by decoding a small metal tag attached to the carb body by a screw." Does he have a Tag? Rhat
KRhat is offline
post #3 of 7 (permalink) Old Mar 15th, 03, 01:45 PM Thread Starter
Misha
Thumbs down
As far as he can tell, there are no tags hanging-off anything.
69 Camaro Z27
69ss350 is offline
post #4 of 7 (permalink) Old Mar 15th, 03, 01:57 PM
Kevin
He's might have a rough time, probably have to take the whole carb in and get some help from behind the counter. Book says that an expert might have to look at the internals for ID. Rhat
KRhat is offline
post #5 of 7 (permalink) Old Mar 15th, 03, 04:31 PM
The 2jet off my 69 307 screamer had a triangular aluminum tag held on by one of the top bowl screws.
BPOS is offline
post #6 of 7 (permalink) Old Mar 16th, 03, 04:20 AM
Smile
Go to the "oldest" local Boney---,, eh, Recycling yard and find some THAT do have the tags on them AND then use them as cores by just rebuilding them by adding the jets out of the old carb's.
This way you won't have a hassle figuring out what carb. rebuild kits you will need for what you have.
And there are two of the suckers, 2G's, small holes, and 2GC's, big holes, if I recall right???pdq67
post #7 of 7 (permalink) Old Mar 16th, 03, 02:34 PM
Angry
Guy's take a look at my homepage. I have pictures of my original carb that Craig Woodruff rebuilt for me atop my 307. It has the tag on it still.
Wacky
wacky174 is offline
