Clutch and pressure plate. - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 29th, 04, 05:50 AM Thread Starter
Gary
69Z28's Avatar
It's been a very long time since I bought my last clutch and pressure plate (probably 25 years). I just removed a 3000 mile fresh 350 from my 69 Z to drop in the 302 and found a brand new 11" set up. The pressure plate is purple, diaphram style and the clutch disc has 10 triangular pads on both sides of it. Never seen anything like this before. Is this a decent set up? I have lauched pretty hard a few times and it seem to hook up very well.
At the very least shouldn't there be lock washers on the bolts that hold the pressure plate on? All but one had flat washers.
And that's not the end...I have only put maybe 1000 miles on this car in 3 years with the 350 and there was always a vibration. I did all kinds of things to find out what it was from and I found out this morning there was no pilot bushing in the crank. Mind you this was a fresh built and balanced engine as was told to me by the person I bought it from. He claimed it was done by a professional. "DOAH" [img]graemlins/clonk.gif[/img]
Lastly, what should the bolts be torgued to when I put the clutch back on? [img]graemlins/beers.gif[/img]
06A 1969 Camaro Z28 X33D80 69 B 711 Black Stripes Console w/tach and gauges.
69Z28 is offline
post #2 of 5 (permalink) Old Apr 29th, 04, 06:56 AM
The only purple plates I remember were made by Zoom, (Perfection Hi-Test). The weren't the best out there, but were certainly good units.
McCloed units are red
Centerforce's are orange
Hays' are gold in color
Be sure to use the correct pressure plate bolts and a lock washer on each... (Mr. gasket offers a skin pack)
torque on the bolts is 35#
chevy torque specs
Hope this is helpful
John...
68ragtop is offline
post #3 of 5 (permalink) Old Apr 29th, 04, 07:16 AM
Vintage 68's Avatar
Originally posted by 69Z28:
'The pressure plate is purple'
'At the very least shouldn't there be lock washers on the bolts that hold the pressure plate on? All but one had flat washers. '
Maybe it's a 'Purple Haze' clutch...
Seriously, many of the resellers will paint the clutch and pressure plate "their" exclusive color to disquise the original manufacturer (they can't possibly afford to tool to make every type clutch) - I don't think their trying to cheat anyone, they just do it to 'stand-out'.
Yes - there should be Lock Washers ( I prefer to use the "Star" type over the "Split" type ).
I also put a little squirt of 'Red' Locktite on each bolt as it inserted - I'm a 'belt-and-suspenders' kinda guy when it comes to these things...
The Bolts are 3/8x16x15/16. Use only "graded" hardware here - factory bolts are grade-5 but I usually replace with grade-8.
Torque to @35ftlbs - unless you use an ARP set, then torque to their spec. (don't remember what it is but remember it being different than stock)
'No pilot bushing' -
That is wierd - I usually run into them even being left in Auto-trans vehicles...
The rebuilder (engine) must have removed and forgot to ask the customer what trans he was going to run.
Bad rebuilder - Bad - go to your room...
Hope this helped - maybe some other "purple clutch" guy will chime-in on who made his...
(edit: thanks 68rag - I do remember now that 'Zoom's' were purple - we put one in my brother's p.u. back-in-the-day...)
ps: hey - I used to live in DE when I worked for 'Uncle Dupie' back in the 80's. Christianna to be exact - isn't Clayton south of there?
[ 04-29-2004, 09:36 AM: Message edited by: Vintage 68 ]
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 5 (permalink) Old Apr 29th, 04, 07:56 AM
Robert
I also think the Zoom pressure plates are purple. Seems like they went away for awhile and have recently made a come back. Might want to check the front bearing on the trans while it's out. That's got to be a strain on it without the pilot bushing.
Robert
TC member #18
rojo is offline
post #5 of 5 (permalink) Old Apr 29th, 04, 03:50 PM Thread Starter
Gary
69Z28's Avatar
Thanks for all the replies everyone.
Vintage68...you are correct. Clayton is about 40 minutes south of Christiana.
I found a Hayes decal stuck to the crank flange so I'm assuming the flywheel is a Hayes. There is a number and a date on the back of the flywheel that is engraved and has a sticker with SFI Foundation with the same number on it.
Thanks again. [img]graemlins/waving.gif[/img] [img]graemlins/beers.gif[/img]
69Z28 is offline
