Help, massive oil leak! - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 12th, 04, 01:07 PM Thread Starter
I was starting to pre-lube my 406 small block and oil shot out of a tapped hole above the oil filter mount. I checked the hole size and it's 9/16-12 size. Should a bolt be in this hole? Any help would be great. Thanks
sanddan is offline
post #2 of 3 (permalink) Old Sep 12th, 04, 02:11 PM
Yes, plug it. Some applications put the oil pressure sending unit there. THIS IS PIPE THREAD! BE SURE TO USE A PIPE THREAD PLUG OR IT WILL GO IN TOO DEEP. Or, if you'll use a gauge and keep the idiot light, put the guage sedning unit there if it''l clear the headers.
post #3 of 3 (permalink) Old Sep 12th, 04, 04:00 PM Thread Starter
JimM,
Thanks for the help. I was looking at the larger hole. The one below it was the pipe thread. I put a plug in and pre-oiled the engine without LEAKS! Yaa! Again, thanks for the help, I was pretty freaked out seeing oil all over the floor. All is good now.
Dan
sanddan is offline
