water leak at intake manifold and head - Team Camaro Tech
post #1 of 4 (permalink) Old May 7th, 04, 09:29 PM Thread Starter
1968 Std.Coupe/327/Holley 4bbl/4spd Saginaw/
10 bolt:3.08
Help!
I just mated the drivetrain after a subframe off restoration and want to turn my attention to the body work and paint.
The problem is, the other day while warming it up, I noticed a small pool of water/coolant where the front corner of the intake manifold meets the driver's side head.
I soaked it up and it didn't seem to leak out again but the gasket was definately wet.
My question is, other than pulling the manifold and resealing it, is there a quick fix I can do to make it work until I get the body/paint done?
The engine did sit for a few years while I worked on the frame, suspension, etc. I haven't tried to re-torque anything yet for fear of making it worse. Is this just the beginning of more leaks?
Thanks in advance,
Dan
68 Std.Cpe./327/Saginaw 4spd./10 bolt 3.08(all numbers match)
thehugger is offline
post #2 of 4 (permalink) Old May 7th, 04, 09:31 PM Thread Starter
here's a pic, see arrow:
post #3 of 4 (permalink) Old May 8th, 04, 01:33 PM
Joe
I would try torqueing the intake manifold bolts working from the center out in a criss cross pattern. After sitting for a while bolts can come loose. If that doesnt work than your best bet would be to remove the manifold and reseal it.
Joekool1234567 is offline
post #4 of 4 (permalink) Old May 8th, 04, 06:56 PM Thread Starter
Sounds like good advice, I'll give it a shot!
Thanks,
Dan
