need info on ZZ3 engine - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 19th, 03, 12:02 PM Thread Starter
Exclamation
i either need a book or a good website for info on the ZZ3 engine. i tried to go to the chevy dealer to see if they had a book there but they didnt. the i bought a 1968 camaro recently with the engine in it and i want to do some stuff to it because it is running a little shaky. i want general info like timing, dwell, ect.
any help at all would be great.
collin is offline
post #2 of 5 (permalink) Old Aug 19th, 03, 03:49 PM
Den
DenRS's Avatar
My brother has a zz3 in his nova. They came with HEI's, so I'm not sure about what you should set the dwell at. I do know that the initial timing should be set at 10 degrees BTDC. I would try the gm performance parts website, they should have copies of the manuals. If no luck there, you should be able to use the zz4 manual. I'm not sure, but I think they changed the intake to get another 10hp.
DenRS is online now
post #3 of 5 (permalink) Old Aug 20th, 03, 05:03 AM
There is no dwell, on HEI.
The timing could be set as high as 14-16 degrees for optimal performance. You really need to go to a dyno or a race track to see if the changes you are making are doing it any good.
You can always do plugs, rotor, cap and wires. An MSD module would probally be the way to go though imo. They run around 80 bucks or so.
MoeSS396 is offline
post #4 of 5 (permalink) Old Aug 21st, 03, 09:32 AM
I have a ZZ3 in my '67 RS. I like the motor and have a manual. Let me know specifically what you are looking for and perhaps I can feed you the answers.
Mister G is offline
post #5 of 5 (permalink) Old Aug 21st, 03, 12:35 PM Thread Starter
im not 100% sure what im looking for. im pretty much just looking for a manual....it would be a good thing to have around.
collin is offline
