Help with engine swap - Team Camaro Tech
post #1 of 6 (permalink) Old May 3rd, 04, 10:49 AM Thread Starter
I own a 92 RS with the rather anemic 6 cyl MPI engine and 5 speed tranny. I recently acquired a strong 350 (some mild head work and balanced and blueprinted) with a single plane manifold and Edelbrock carb. I need some help with what I'm going to have to do to swap out the 6 cyl. for the 350. My main concern is what pieces will I need to get the tranny to mount to the new engine? Will I need a bigger radiator? I have the right engine mounts for the swap and that's about it. ANY help would be appreciated.
ticket Magnet is offline
post #2 of 6 (permalink) Old May 3rd, 04, 12:38 PM
Call me Funk
Send a message via AIM to CFunK
The guys over at www.thirdgen.org can fix you right up.
-Funk
CFunK is offline
post #3 of 6 (permalink) Old May 4th, 04, 09:45 AM
a67
The bellhousing won't work, need a V8 bell. To use the trans a clutch disk with a V6 center and a V8 pad area needs to be made. Or get a V8 trans (input shafts are different).
Engine frame mounts need to be changed out for V8 ones. If you stay with an f-body 700R4 or a T5 then the driveshaft is the same. Not sure on the crossmember, GM was swapping stuff around on the '90-'92 models.
Bob.
a67 is offline
post #4 of 6 (permalink) Old May 5th, 04, 06:00 PM Thread Starter
Thats the crucial bit of info I was looking for. Thanx for the help guys, you definately beat my local Chevy dealership for information. One other question though. Along with other parts and pieces I have a Buick 3.8 liter turbo system and a NOS set dry shot set up. Will the turbo system (with some minor plumbing mods) be a feasible accessory on my 3.1 liter V6? Which one of these routes is going to be a bigger nightmare in your opinions? Just thought I'd check out all my options before jumping in head first. Thanx.
post #5 of 6 (permalink) Old May 5th, 04, 07:37 PM
imho the v8 swap would be easier,if it was me i'd check out building the v8 with the small turbo since you have the parts?
Eric
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
post #6 of 6 (permalink) Old May 5th, 04, 07:38 PM
i know someone will beat me up for that one!
