Anybody else have this problem? - Team Camaro Tech
post #1 of 16 (permalink) Old Jul 22nd, 03, 02:22 PM Thread Starter
The stock radiator hose that's on my 67 camaro hits the altenator bracket. It pushes it so hard that it collapses the hose a little. What is the correct hose for this type alt bracket? Here's a pic. It seems I need one that doesn't drop down from rad. and goes a little more toward the center of the motor. Thanks
1967 Camaro coupe Deluxe interior LT-1 350 w/ 4spd. M-21 trans and 12 bolt rear.
RamJam is offline
post #2 of 16 (permalink) Old Jul 23rd, 03, 03:16 PM
Looks like the wrong bracket, or the bracket is bolted to the wrong side of the alternator mount, or both.
run-a-way-69 is offline
post #3 of 16 (permalink) Old Jul 23rd, 03, 03:34 PM Thread Starter
Unhappy
The bracket is stock on my car also stock altenator never replaced and I've owned it since 1977. I changed to the 350 in 1981 that's when I went to the tougher flex rad hose but I like the stock hose better. If I move the altenator to the other side of bracket it will be way off from the w/pump pulley. I've looked at other engines and it looks like the same setup. The bracket is bolted the only place it can be bolted. Any other ideas?
RamJam is offline
post #4 of 16 (permalink) Old Jul 23rd, 03, 03:48 PM
I think you need to bolt the bracket to the front of the Alt. Thats how Ive always seen them down. Nice engine, but a 1970 LT1 shouldnt have an oil fill tube going into the block, should be in the valve cover.
MoeSS396 is offline
post #5 of 16 (permalink) Old Jul 23rd, 03, 05:00 PM Thread Starter
Smile
Moe,
Below is a pic of a stock 67 327 camaro with the alt the same place mine is in front of bracket. I know the manifold isn't correct but it's a stock hi rise and I like it. Thanks
[img]smile.gif[/img]
RamJam is offline
post #6 of 16 (permalink) Old Jul 23rd, 03, 05:09 PM
ZZ_430's Avatar
This swivel t-stat housing from CSI should take care of it. You could angle the hose away from the bracket. Remove the oil filler tube, and plug the hole in the manifold with a soft plug. You could use a valve cover breather.
Summit also sells their own version for much less $.
http://store.summitracing.com/produc...earchtype=ecat
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #7 of 16 (permalink) Old Jul 23rd, 03, 05:16 PM
Chad
67 Plum's Avatar
I just checked my 67 and the bracket is bolted in front of the alt. But I dont think that 1/2 inch front or back would cause trouble might look at a different water neck one that is angled up more.Also moght look at other brands of hoses different brands can be shaped different for the same application.Hope this helps.
67 Plum is offline
post #8 of 16 (permalink) Old Jul 24th, 03, 08:43 PM Thread Starter
Smile
Hey Guys,
Here's 2 more with bracket setup like mine and the bottom one looks untouched. I have mine apart now I'll figure something out. Thanks
RamJam is offline
post #9 of 16 (permalink) Old Jul 25th, 03, 03:49 AM
The hose that you have should be okay. It looks like you're using a chrome, aftermarket thermostat housing. The hose outlet angle on that might be different than a factory one. Try a stock GM housing. Depending on what year your intake is, you might even need the cast iron housing from a Corvette/Z28.
'67 SS/RS (RR)
'68 RS conv. (J2)
'68 Z/28 (VV)
'68 Drag Car(ZZ) 11.30 @ 118
'73 Corvette Drag Car 12.64 @ 106
Kyvox is offline
post #10 of 16 (permalink) Old Jul 25th, 03, 03:59 AM
a67
Try a hose from a '78 El Camino (w/305). It has a better form to clear the alternator.
Bob.
a67 is offline
post #11 of 16 (permalink) Old Jul 25th, 03, 10:35 AM
If you haven't tried already, try getting a thermostate housing that swivels so you can adjust it to where you can adjust it so your radiator hose doesn't hit it. You can find these in summit racing or the Jegs catalogs
Derrick Tarrance is offline
post #12 of 16 (permalink) Old Jul 25th, 03, 08:24 PM Thread Starter
Smile
a67,
I'll check out that hose. That would be the quickest fix. Hate to say this Moe and 67 plum but it's possible your altenator is on the wrong side. Thanks for your help guys.
RamJam is offline
post #13 of 16 (permalink) Old Jul 26th, 03, 05:38 AM
DjD
DjD's Avatar
I think your upper hose is wrong. Just for reference I looked in a Year One catalog I have and it looks like you have a '69 or possibly a '67-'68 Z/28 upper hose not a '67.
For small blocks there are 4 different hoses for '67 (except Z/28), '67 & '68 Z/28, '68 (except Z/28) and '69.
What if you loosened the clamp at the radiator and twisted the hose counter clock wise? Would it raise the hose high enough off the belt to make do? For less than $20 I'd get the right parts...
...Dennis
DjD is offline
post #14 of 16 (permalink) Old Jul 31st, 03, 05:54 PM Thread Starter
Angry
Ok, Here's how I fixed it. I took off the stock brakt replaced it with a chrome Mr. Gasket brkt. I also enlarged the slots in the lower brkts now everything looks good and hose fits w/out being crimped. Thanks guys
[img]graemlins/thumbsup.gif[/img]
RamJam is offline
post #15 of 16 (permalink) Old Aug 3rd, 03, 08:20 PM
David Pozzi
davidpozzi's Avatar
Look at the 67 hose above, it has an extra bend near the radiator which helps it clear better.
The 67-68 Z/28 hose is #3892650
I think DJD is right, yours is a 69 hose which has no alt bracket to clear on that side.
davidpozzi is offline
