Cranking pressure 130? - Team Camaro Tech
post #1 of 13 (permalink) Old Apr 30th, 04, 02:16 PM Thread Starter
I just did a compression test on my 383 and its only at about 130-135 on all cylinders. This doesnt seeem right at all with my compression ratio. Maybe my starter is not fast enough? What rpm should I be cranking the engine over to get an accurate reading? I figured my engine should have atleast 180 pounds or so.
nitrous383 is offline
post #2 of 13 (permalink) Old Apr 30th, 04, 02:30 PM
JohnZ's Avatar
Is it warm and do you have the throttle blocked wide open while cranking? Getting 4 or 5 compression strokes before taking the reading? [img]graemlins/thumbsup.gif[/img]
JohnZ
CRG
JohnZ is offline
post #3 of 13 (permalink) Old Apr 30th, 04, 02:39 PM
Matt Jones
You know, what I learned about that is that it's relative. If you had 180 before and now you have 130, then you may worry.
For example, I did my pressure test on my 412, and it read 265PSI ! I bought a new gauge, and it was down to a normal 220PSI.
So, I would borrow another gauge and see what it says.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #4 of 13 (permalink) Old Apr 30th, 04, 04:18 PM
Your cam will have a big impact on static compression readings as well. And ditto on blocking the throttle open.
dnult is offline
post #5 of 13 (permalink) Old May 1st, 04, 12:23 PM
Eric
Mine reeads right around 215-220 psi but that is with my gauge. Unless a gauge is bad, it should be fairly close to reality . . .
Eric68 is offline
post #6 of 13 (permalink) Old May 1st, 04, 01:27 PM Thread Starter
Well, thats what I thought. I figured mine should be atleast 180, so 130 doesnt seem right at all. I can only think of a few things that are causing this.
1) The gauge is bad (though unlikely its a new MAC)
2) I installed my cam off by a tooth or two and retarded the cam timing
3) My timing chain is toast and the stretch has retarded the cam timing a bunch. How much would it have to be off to make a 60 psi difference in cranking pressure?
I will be checking again with the carb wide open and a different gauge asap.
post #7 of 13 (permalink) Old May 1st, 04, 01:54 PM
Matt Jones
The timing chain would have to be pretty far off. When I installed my cam, I wanted to see how the cranking compression changes as I advance and retard the cam. What I found was that moving the cam 4* either way changed the compression by 10-15PSI. Not a whole lot.
If that were the case, you'd have to be off by 20* or so.
Matt Jones
post #8 of 13 (permalink) Old May 1st, 04, 03:24 PM
It ran 114 in the quarter, right? There can't be a whole lot wrong unless the performance has deterated since then.
oger is offline
post #9 of 13 (permalink) Old May 1st, 04, 05:28 PM
Joe
Angry
Mike, you have mail
Joe G
69 Coupe; ZZ430; TKO600; 3.55 posi; 13" Baer 4 wheel discs; 17" Billet Specialties wheels; Hotchkis/Koni rear; Ride Tech front; Classic AutoAir AC and power windows cuz I'm old and lazy!
Joe G is offline
post #10 of 13 (permalink) Old May 2nd, 04, 08:21 AM
Thanks Joe
oger is offline
post #11 of 13 (permalink) Old Nov 23rd, 04, 09:06 PM Thread Starter
Angry
I finally did another compression test with a brand new gauge, I also changed my method. I wired the carb to full throttle, pulled the plugs and hooked up a battery charger. It spun much better than last time and I got 198-200psi on all cylinders, that sounds better than 130. I was amazed there wasnt more than 2psi difference between all cylinders, which is great.
post #12 of 13 (permalink) Old Nov 24th, 04, 03:03 AM
Eric
Thanks for the update. Having the engine throttled when doing thetest is most likely what made the numbers low. 2 psi is pretty consistent.
Eric68 is offline
post #13 of 13 (permalink) Old Nov 25th, 04, 04:36 PM
200 psi sounds about right. My 388 has 1 point less compression and the same cam, and cranks 185psi.
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
