350 and 305 piston rods - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 27th, 01, 02:28 PM Thread Starter
Hello, I was wondering if I could use the piston rods out of a 305 in a 350?? I am just building the 350 to stock specs. And could I use the crankshaft out of the 305 in a 350 too?
thanks
carcrazy65 is offline
post #2 of 8 (permalink) Old Jan 27th, 01, 02:52 PM
Yes the rods are the same. The crank is the same also as long as they have the same style rear seal (one piece or two piece). The difference betweena 305 and 350 is the bore size.
Stephen
67 RS/SS 350 700R4
69 SS clone unfinished
72 454 Weekend Racer
[This message has been edited by squarles (edited 01-27-2001).]
squarles is offline
post #3 of 8 (permalink) Old Jan 27th, 01, 03:04 PM
Freddie
If you use a 305 crank in a 350 it needs to be reballanced.
'69 RS/SS396 pro street
427/4spd/9"
big gear head is offline
post #4 of 8 (permalink) Old Jan 27th, 01, 04:33 PM Thread Starter
Talking
Thank you very much. I thought that they were the same, but I just figured that I would make sure.
post #5 of 8 (permalink) Old Jan 27th, 01, 09:18 PM
They are dimensionally the same but the factory balance job is different...the 305 is balanced for lighter (smaller bore) pistons (same for the crank)...so you definately need a balance job if using these parts on a 350. Around here balancing costs about $150
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #6 of 8 (permalink) Old Jan 28th, 01, 03:55 AM
So in other words, get yourself a 350 crankshaft and leave the 305's for the 305's
69 rallye green X77 Z/28,1967 SS 396 Conv. 1974 c-10 454 swb
pipeman is offline
post #7 of 8 (permalink) Old Jan 28th, 01, 06:04 AM Thread Starter
I was most concerned about the piston rods. Would I have to get them balanced too?? I have the crank, but I need piston rods.
post #8 of 8 (permalink) Old Jan 28th, 01, 12:02 PM
JohnZ's Avatar
You need to have the entire rotating/reciprocating assembly balanced - crank, rods, pistons/pins, damper, flywheel; shop will equalize the weight of the rod/piston/pin sets and make up bob weights to match the equalized weight, then balance the crank with the damper, flywheel, and bob weights attached.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
