pulley pressed in too much? 68 camaro - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 19th, 04, 10:58 AM Thread Starter
Can't figure out why I keep tossing belts. Looks like my water pump pulley is pressed in too far. What do you think?
Check it out here
68 Z/28, grotto blue, protect-o-plate
67 plain jane survivor, deep water blue, protect-o-plate
SooperDave is offline
post #2 of 10 (permalink) Old Apr 19th, 04, 11:00 AM Thread Starter
try this one
post #3 of 10 (permalink) Old Apr 19th, 04, 11:34 AM
Eric
I was seeing that right, it looks like the crank pully is what is in too far. You could put a spacer behind the crank pulley (you'd have to make it) or you could get a different w/p pulley that sits back a little further.
The pulleys must line up!! That is why you are tossing belts.
Eric68 is offline
post #4 of 10 (permalink) Old Apr 19th, 04, 04:18 PM
I think I have read where rebuilt waterpumps tend to not have the pulley mount plate pressed on to the CORRECT or FACTORY depth which makes this pulley alignment problem.
You can press it farther in or out to fix it or space your pulley's whichever one is easiest to do..
Isn't there something like three factory length waterpumps b/c of the outlet leg lengths and the pulley plate being different?? I know there is short and long legged ones...
pdq67
post #5 of 10 (permalink) Old Apr 20th, 04, 04:38 AM Thread Starter
yeah the z28 has a short water pump, but maybe i can pull the pulley out a bit. or i might just make a spacer - don't feel like removing the water pump again
post #6 of 10 (permalink) Old Apr 20th, 04, 01:18 PM
I think you can buy them, but I forget who from??
Like a 1/32", 1/16" and 1/8" or something like that in a set????
pdq67
post #7 of 10 (permalink) Old Apr 21st, 04, 11:08 AM
Eric
pdq67
Yes, there are three lengths -- short, long, and Corvette
Eric68 is offline
post #8 of 10 (permalink) Old Apr 21st, 04, 11:46 AM
Vintage 68's Avatar
pdq67
Years ago I used the set from Mr. Gasket (is this 'Spectre' now?) and I think the ones Speedway - http://www.speedwaymotors.com/xq/asp...qx/product.htm - sells are the same.
Canton Racing also used to sell misc. spacers for many applications.
1968 Convertible
Some trucks
Vintage 68 is offline
post #9 of 10 (permalink) Old Apr 22nd, 04, 04:54 AM Thread Starter
Originally posted by Vintage 68:
</font><blockquote>quote:</font><hr />Originally posted by pdq67:
pdq67
Years ago I used the set from Mr. Gasket (is this 'Spectre' now?) and I think the ones Speedway sells are the same. Canton Racing also used to sell misc. spacers for many applications. </font>[/QUOTE]Thanks - this is perfect!!!
post #10 of 10 (permalink) Old Apr 22nd, 04, 12:13 PM
Lonnie
Once a belt gets thrown, even if you fix the alignment issue, it will keep coming off. You have to get a new belt. That's how it was with me anyway. Dacco Top Cog belts are by far the best I have used.
67 Camaro [email protected], [email protected], 1.455 60ft 421sbc
Lonnie67 is offline
