Target Master 350s - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 23rd, 04, 01:18 PM Thread Starter
Anyone know if they have steel shim head gaskets? A friend is putting one in a boat that will get salt water in the cooling system.
oger is offline
post #2 of 6 (permalink) Old Dec 24th, 04, 07:53 AM
about 10 years ago buddy put one in his 4x4 and it had shim steel gaskets, maybe they changed since then?
68 Camaro~LSx ~all motor
post #3 of 6 (permalink) Old Dec 24th, 04, 09:06 AM
The last one I was in to was about 12-13 years ago...and it also had a steel shim gasket.
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #4 of 6 (permalink) Old Dec 31st, 04, 10:45 PM
sounds like you want to look into stainless shims?
E
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
post #5 of 6 (permalink) Old Jan 2nd, 05, 01:51 PM
I swapped the heads on one that was a couple years ago. They're were not steel head gakets. Some sort of paper/composite design.
MarkM is offline
post #6 of 6 (permalink) Old Jan 4th, 05, 08:09 PM
Matt Jones
Mine were composite.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
