after market clutch set - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 8th, 02, 04:38 PM Thread Starter
hey guys what are some of the best after market clutch sets that you have purchased and had good luck with.i am talking about 4 speed manuals.i dont need any thing for a top fuel car just for about 275 hp.thanks jeff
68 redcam is offline
post #2 of 7 (permalink) Old Apr 8th, 02, 04:57 PM
Centerforce is the one. Many people I respect are sold on them. I have the Dual Friction setup on my car.
-Mark.
stingr69 is offline
post #3 of 7 (permalink) Old Apr 8th, 02, 05:45 PM
sonny
Same here with the Dual friction setup.Does not slip at all...... Well, not with a basically stock 350 lol
67ssrs350 is offline
post #4 of 7 (permalink) Old Apr 9th, 02, 05:51 AM
I am also a Centerforce fan. Just put the Centerforce II behind my warmed over 396/Muncie combo. Pedal pressure is the same, doesn’t slip and is easy to drive in traffic. While you are in there check out GM’s 15 lb. Flywheels. A little cranky when the engine is cold but you will love the throttle response.
Gene H is offline
post #5 of 7 (permalink) Old Apr 9th, 02, 10:31 AM
Gene
Centerforce makes very good clutches. Sounds like you have a mildly built engine, so the Centerforce II would be fine. Stay away from the lighter flywheel. Throttle response might be better, but driveability suffers. I know because I have one.
gheatly is offline
post #6 of 7 (permalink) Old Apr 9th, 02, 02:22 PM Thread Starter
hey guys any of you had any experience with ram power grip clutches or borg warner.centerforce is a little pricie .thanks jeff
post #7 of 7 (permalink) Old Apr 11th, 02, 04:45 PM
JohnZ's Avatar
Jeff -
With all the work involved in a clutch job, why worry about a few more bucks for a top-quality clutch? Do it once and do it right so you don't have to do it again. I've used Centerforce II's in six different project cars over the last eight years, wouldn't even think about using anything else.
JohnZ
CRG
'69 Z28 Fathom Green
JohnZ is offline
