Attn: CarlC Valve cover gromets and baffles... - Team Camaro Tech
post #1 of 11 (permalink) Old Sep 9th, 03, 11:33 AM Thread Starter
DjD
DjD's Avatar
Hi Carl,
Refrencing your valve covers or actually the breather hole gromets.
I have the same valve covers and run a PCV to the base of the carb. I have rubber gromets that don't leak but don't have a baffle and am sucking oil like you can't believe. My question is where did you come up with the gromet assembly you are using and is it a two piece that screws together, top and bottom to hold it to the valve cover. If so I could fabricate a baffle and use the same to hold it in place...
If the graphic doesn't load in the forum, it's alt_1.JPG from your web page... http://www.geocities.com/casanoc/
Thanks in advance!!
...Dennis
DjD is offline
post #2 of 11 (permalink) Old Sep 10th, 03, 07:26 AM Thread Starter
DjD
DjD's Avatar
ttt
...Dennis
DjD is offline
post #3 of 11 (permalink) Old Sep 10th, 03, 07:33 AM
Rick
Dennis, Carl had told me he was out of town for the week so he may not see thus until the weekend. However, a while ago Carl had sent me the 'right angle' pcv valve he uses which along with a Moroso baffle with the slit in the bottom , gave me the setup you see in his website. A nice sanitary affair.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #4 of 11 (permalink) Old Sep 10th, 03, 09:13 AM Thread Starter
DjD
DjD's Avatar
Thanks for the heads up Rick. Are you refering to a rubber gromet baffle. The ones that look like a plug but have a slit in them to reduce the oil pickup into the pcv?
...Dennis
DjD is offline
post #5 of 11 (permalink) Old Sep 11th, 03, 02:40 AM
Rick
Yes, the one I use has the step in the bottom with the slit facing to the side.
Rick Dorion
RickD is offline
post #6 of 11 (permalink) Old Sep 11th, 03, 05:43 AM
Jody
camcojb's Avatar
Dennis,
I believe he's talking about the MRG #5425; not just a slit in the bottom, but a stepped baffle.
Jody
camcojb is offline
post #7 of 11 (permalink) Old Sep 11th, 03, 06:13 AM Thread Starter
DjD
DjD's Avatar
Thanks for the pic Jody, I found these Moroso 68775's with the slot. and 68772's with a discription
Designed especially for those using Moroso extra tall valve covers without the integral OEM-style oil control baffle. Can be used with any valve cover without internal baffling and a 1.22" diameter hole. Works with all popular GMPCVvalves; 1 per package. Special design keeps oil out of the PCV valve; made from oil resistant rubber. Will not clear stud girdles
Do you think the 68772's are the same as the 5425's?
...Dennis
DjD is offline
post #8 of 11 (permalink) Old Sep 11th, 03, 06:23 AM
Jody
camcojb's Avatar
The 68772's look like they're made for a pcv to go straight into; smaller hole in the top. The 5425's are for a breather which won't work for you if you want to put a pcv valve straight into them (sorry!!!).
The description for the 68772 says pcv grommet/baffle; sounds right to me.
Jody
camcojb is offline
post #9 of 11 (permalink) Old Sep 11th, 03, 06:27 AM
Rick
Actually they work with a stud girdle. You just need tall valve covers, double up the VC gaskets and trim a little!
Rick Dorion
RickD is offline
post #10 of 11 (permalink) Old Sep 11th, 03, 03:29 PM
Carl
Dennis,
Yep, I'm in Louisville this week. The Louisville Slugger plant is very cool!
We may have different covers. Mine are a mid-height GMPP cover that have both holes and baffles. There is a picture of them on the Sallee website.
I just use a standard grommet, the PCV arrangement listed above, and a fresh air tube plumbed to the air cleaner base. The PCV is really nice. If anyone wants one I can find the phone number for the guy that sells them or buy one for you. For the valve and the adapter bushing is about $60.
If I ever get versed in html I can move my website to my cable modem company server and dump the non-linkable geocities site.
Carl
CarlC is offline
post #11 of 11 (permalink) Old Sep 12th, 03, 06:26 AM Thread Starter
DjD
DjD's Avatar
Mine are the tall version...
No holes until I got ahold of them and no baffles!! I picked up an off brand gromet baffle that looks like the mrg5425 on the under side and fits the pcv valve I'm using for a dollar. I have one slight problem though!! The hole saw I used left me with a 1 5/16" hole instead of a 1 1/4" hole. I think I can improvise and make it work without too much problems... I had a bit of a search finding gromets that fit in the first place!! You should have seen my reaction after measuring the holes!!
Thanks for the info guys...
...Dennis
DjD is offline
