Oil consumption - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 2nd, 04, 09:20 AM Thread Starter
Hi,
I have som problems with my chevy engine! VERY high oil consumption!
I have checked everything and I am sure the oil comming from below thru my cylinders.
The cylinder bore is 4.310 and the pistons i use is wiseco with Total seal ring set!
Second ring is gape less!
I have measured the piston to wall clearence to .004 on all cylinders and wiseco recommend .005!
The top ring cyl 2 has very small cracks that I think is caused by oil in the combustion camber that will lower the octane ( excuse my bad english, I am from sweden he he)
The engine needs 1 litre extra oil in 150km driving.
Maybe i should try another rings set but I dont see wy the oil consumption is so high
Thank you for a nice forum by the way...
jimmy
Terracan is offline
post #2 of 9 (permalink) Old Apr 2nd, 04, 11:30 AM
Ouch, that's a lotta oil. Just a thought, but have you ruled out a leak on the under side of the intake, sucking oil into the cylinders? How do the plugs look, all 8 dirty?
post #3 of 9 (permalink) Old Apr 3rd, 04, 12:51 AM Thread Starter
Hi,
All plugs are very dirty! I have already checked this ting. The top of the pistons are clean in the edges and dirty in the middle, this telling me that the oil comming from below.Dirty in the edges and clean in the middle means that oil comming from heads or intake manifold! The oil I am using is 20w-50 castrol I think!
How important is deglazing?
Br jimmy
Terracan is offline
post #4 of 9 (permalink) Old Apr 3rd, 04, 05:20 AM
Jody
camcojb's Avatar
Hate to tell you but I haven't got a SINGLE SET of those rings that didn't use oil, and smoke under WOT. And I've tried them in several motors with pro shops doing the cylinder wall prep to Total Seals exact specs. I quit trying, swapped to Speed Pro Plasma Moly's and haven't had a problem since (in probably 15 motors or so). The Plasma Moly's seat quick and don't use oil.
This topic has come up on several car boards I'm on, and I'd guess 90%+ of the guys who respond had the exact problems you and I did.
Jody
camcojb is offline
post #5 of 9 (permalink) Old Apr 3rd, 04, 07:22 AM Thread Starter
Hi,
Today I noticed that the top ring in 3 cylinders of 4 was turned upside down.
I have studied little about speed pro rings and they seems good to me but there is a problem and it is the honing job has to be done for seating the new rings!
Is there any possibilities that I can do this by my self?
Is there any instructions in the internet?
Thanks jimmy
Terracan is offline
post #6 of 9 (permalink) Old Apr 3rd, 04, 08:58 AM
Royce
Jody, I know you have mentioned that before. I have still yet to have problems with any of my Total Seal rings. I used them in my current engine as well. Is there any chance you were using the light tension oil rings? Just curious.
Yes, the walls have to be de-glazed and prep'd properly if you just stuck the rings in worn cylinders this is more than likely why you had a problem. Also with some rings being upside down that doesn't help.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #7 of 9 (permalink) Old Apr 3rd, 04, 09:14 AM
Jody
camcojb's Avatar
Royce,
If they were low tension (which is a thought I had) they were supplied in their sets. I didn't order a race set, just the street style rings.
Jody
camcojb is offline
post #8 of 9 (permalink) Old Apr 4th, 04, 09:04 AM
Royce
Jody, I have yet to come close to WOT so we'll see what happens. With my last set I ran them for 6 years no problems at all. I am actually going to put a set of bearings in that engine and a buddy of mine is going to run it. I will keep an eye out for white smoke at WOT and I will let you know. I think I am really testing them because of the 6" rods putting the pin into the oil ring groove. I have heard this will/can cause oil consumption, though I have done it before with no problems as well. Give me a few weeks and I will give you an honest answer good or bad. I am sure at this point you have your mind made up and my results won't change that. If I had the "bad" experiences you had I wouldn't change my mind either.
post #9 of 9 (permalink) Old Apr 4th, 04, 09:48 AM
Jody
camcojb's Avatar
No problem Royce. I'm interested in your opinion. I tried them on blown and N/A engines, but as I think about it they may have all been 6" rod motors too, with the support rails. But like you said, the Speed Pro rings had no problem either, so I believe it's either the oil ring they use(d) or a lot of engine builders think it has to do with the second ring being sealed off.
Jody
camcojb is offline
