502? - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 22nd, 04, 10:52 AM Thread Starter
Right now I am in the what if period of building my 68, I know that a 502 would fit in my car, but all the cars I have seen with the 502 have roll cages for added frame rigidity. I have a convertible and don't necessary like the thought of have to add a cage. If I went the 502 route would I have to add the cage and secondly the car is an ac car, will it support ac?
phoenixdawg is offline
post #2 of 8 (permalink) Old Dec 22nd, 04, 08:26 PM
hey phoenixdawg - you don't need a cage - a 502 will work fine in your 68 and it will support ac assuming you get the correct brackects etc etc. If your car was a SBC car you'll need to change the heater box to one fron a BBC camaro, along with the frame mounts. A gen IV BBC(454) and Gen V & VI (502) big blocks are the same dimentions externally - The Gen V & VI (502) big blocks do not have provisioins for a fuel pump....I would however put sub frame connectors in it IMHO. But it really depends on your driving style and use.
[img]graemlins/thumbsup.gif[/img]
Rat Touring 1969 Camaro X44 496 Richmond Super T10 Plus 4-Speed 3.55 4 wheel disc
..and sporting all new suspension, wheels, etc etc... take a look...
nick V is offline
post #3 of 8 (permalink) Old Dec 26th, 04, 04:00 PM Thread Starter
thanks for the tips Nick, I really think the 502 would be a sweet setup, what tranny would you run
post #4 of 8 (permalink) Old Dec 28th, 04, 06:04 PM
Hey Phoenixdawg, I am also looking to stick a 502 in my 67 and according to GM they strongly suggest putting a th400 or a 700r4 tranny that has been set up to handle the horsepower. I am really new at all of this so if you have any info on what type of suspension you are going to use to handle the beast let me know!!!
Todd1312 is offline
post #5 of 8 (permalink) Old Dec 28th, 04, 07:01 PM
Hey phoenixdawg - I'm running a Borg Warner Super T-10 with a lakewood blowproof, and Ram Pressure palte and brass clutch. Will be swapping it out later this year for a TKO-600, well at least after the upcoming birth of my second daughter... my 468 makes great power - but I'm looking to step up to a 540 CID - so much for the college fund LOL
nick V is offline
post #6 of 8 (permalink) Old Dec 30th, 04, 12:55 PM
I have a 502 b.b. in my 69. If you would like more info on my build, e mail me. I run a/c and no cage.
jbird is offline
post #7 of 8 (permalink) Old Dec 31st, 04, 06:44 PM Thread Starter
Todd 1312 my the suspension that I am running will be the stock set up as far as the fronts, I rebuilt all of that last fall, new bushings, idler arms, pitman arms, tie rod ends, hotchkis 2" drops, etc. As far as the rear, I am replacing the rear leaves with new hotchkis springs this weekend and I plan to rebuild the rear end with something on the order of a 3.42 limited slip diff on a GM 12 bolt, still may decide to bolt up a Ford 9" but am undecided. I am really leaning toward the 12 bolt.
post #8 of 8 (permalink) Old Jan 1st, 05, 06:55 PM
since you like hotchkiss(i do too)might want to spring for a set of their subframe connectors.
E
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
