STICKY VALVE - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 10th, 03, 08:00 AM Thread Starter
MY 67 CAMARO WHICH I PURCHASED 3 WEEKS AGO HAS HAD ONLY 1665 MILES PUT ON IT"S 350//295 HP, ENGINE SINCE IT WAS TOTALLY REBUILT IN 1987.CAR USED AS SHOW CAR ONLY! CAR SAT FOR EIGHT MONTHS BEFORE I GOT IT FROM ESTATE. HAD A ROUGH IDLE TO IT & UPON ACCELERATING HAD A MISS. DID COMPLETE TUNEUP & CARB REBUILD. NO BETTER.!! PULLED VALVE COVERS TO FIX GASKET LEAK & NOTICED LOOSE ROCKER ARM.THERE IS A STUCK VALVE IN THE OPEN POSTION. WHAT IS THE EASIEST OR BEST WAY TO GET THIS FREE TO POP BACK INTO POSITION . DO NOT WANT TO PULL HEAD UNLESS ABSOLUTELY NECESSARY!
Rick Stewart is offline
post #2 of 4 (permalink) Old Oct 10th, 03, 08:38 AM
robert
rolling-robert's Avatar
*my ears*
just pry a screwdriver between the spring and force it upwards.
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #3 of 4 (permalink) Old Oct 10th, 03, 12:53 PM
Cool
Spray her down good with some Liquid Wrench or PB-Blaster and be real careful when prying with a screwdriver or any other pry-bar that you don't knick the spring !!
B/c if you do, you have created a stress-riser on it's surface and the sucker WILL break later, thus dropping a valve!!
And even a spot of water-caused rust on a valve spring WILL do this too!!!
Been there and had that happen to the Company's "Gunning Truck" once after a complete short block change-out and overhaul!!!
pdq67
post #4 of 4 (permalink) Old Oct 10th, 03, 01:52 PM
Bill
Rick,
You can try tapping the top of the valve with a plastic hammer and see what happens. Maybe spray some PB Blaster on it first and let it soak. However, it has been our experience that once a valve sticks, the stem is probably starting to gall up and the head will have to come off. We have seen a bunch of this lately on cars that are not driven much, especially intake valves. I personally think the unleaded fuels now days tend to gum up a lot quicker. I remember starting cars up when I was a kid that we knew had been sitting for several years, and never having a problem.
Hope this helps,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
