Wrist pin - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 5th, 04, 06:41 AM Thread Starter
Hi again,
I have noticed that my rod is not in the center between the piston walls inside.
The wrist pins is pressed in to the rod!
This is not good I think. Can i adjust this by myself by force the wrist pin to center a little or do I need to heat the rod?
Br jimmy
Terracan is offline
post #2 of 6 (permalink) Old Apr 5th, 04, 06:48 AM
Vintage 68's Avatar
Do NOT heat the Rod while assembled
We need more info on how you are viewing this assembly.
Is the piston in the bore and the rod on the crank?
Are you looking up from the bottom (or down if the engine is on stand) in the bore?
The pin is press-fit and should be centered on the rod. It may shift back and forth in the piston if the assembly is removed from the bore and held in your hand.
The rod should be fairly centered in piston, when viewed in the bore from the bottom of piston side.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 6 (permalink) Old Apr 5th, 04, 07:54 AM
Bill
Jimmy,
What pistons are you using ? If you are trying to use a piston with a snap ring, like the Keith Blacks, you cannot use the snap ring if the piston is pressed on the rod. The rod has to be able to move back and forth to center itself.
If you are not using a piston with snap rings, it is not real critical for the pin to be exactly centerd, but it should be close.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #4 of 6 (permalink) Old Apr 5th, 04, 08:39 AM Thread Starter
Hi,
Thanks for your support..
When I have the WISECO piston (with the rod mounted)in my hand I can push the piston untill it is nearly touching the right piston wall inside, then it is stopping cause of spirolocks. When I push the piston to the left it passes the center approx 0,75mm and then raches the spirolocks.
This means that wrist pin is not centered!
I hope you understand my english
Br jimmy
Terracan is offline
post #5 of 6 (permalink) Old Apr 5th, 04, 10:01 AM
Royce
If you have pressed pins/rods you do not "need" the spirolocks.
Your rod side clearance on the crank should not allow that much movement once it is assembled.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #6 of 6 (permalink) Old Apr 5th, 04, 01:53 PM
Bill
Jimmy,
Just want to repeat what Royce said. Take the spiral locks out if you have the pins pressed in the rods or you will have major damage when you start the engine. The spiral locks are only used when the pin is a floating fit in the end of the rod. Take the locks out !
Bill Koustenis
Owner
Waldorf Md
BillK is offline
