Engine stands - how do judge quality? - Team Camaro Tech
post #1 of 10 (permalink) Old Sep 5th, 03, 01:01 PM Thread Starter
Peter
There are a lot of people selling engine stands - for example http://cgi.ebay.com/ebaymotors/ws/eB...category=35625
- but how can you tell if it is a quality piece or will fall apart on you? Would anyone recommend a particular brand? Some of the large companies, e.g, Jegs, etc. sell stands but they are a lot more expensive, and I'm not sure whether the quality is any different. What to do?
Peter
coach420 is offline
post #2 of 10 (permalink) Old Sep 5th, 03, 01:09 PM
Some engine stands look pretty flemsy, but I've never heard of one falling apart. There is no need to have a 2000 lbs engine stand. If you're not rebuilding engines for a living, the $49 stands and Harbor Freight are adequate. The only component of an engine stand that I would concern myself with is the wheels. I prefer the heavy cast rear wheels and ball bearing front wheels. I believe most have them.
-dnult
dnult is offline
post #3 of 10 (permalink) Old Sep 5th, 03, 01:11 PM
Angry
There was a special on "Hot Rod T.V." or "Trucks" or something like that where they compared a few different brands. Besides name brand, color & shape there were few differences.
There are some main differences that Im finding out due to the fact that I have a engine on a stand right now and noticing some things that I would like to change.
1. Make sure that it has some decen tsize wheels like around 3-4 inch diameter and make sure that there very, VERY hard rubber not metal. The ones on mine now are small metal and God forbid that you runs across a speck or "oil dry" because it will lock a loaded engine stand up.
2. Its usually better to have a 4 leg stand than a 3 because a oil drain pan or bucket is hard to balance on a third leg located right below the oil pan when you can buy one with 4 legs so that the pan will sit right between the 2 front ones.
3. All should have it by now, but make sure that it has a locking pin/bolt/something to keep the engine from sliding forward and falling outof the engine stand.
These are just my opinions and I say that because Im working with my fathers engine stand right now, and it has "senamental" value because it was his grandpa's so it lacks a few nice traits that the newer ones have. Hope that this helped!
speedball1969 is offline
post #4 of 10 (permalink) Old Sep 5th, 03, 03:59 PM
Vintage 68's Avatar
'how to judge quality?' - in most cases, Price!
My best - is an 'Ing's' (spelling?) I got from a truck shop auction many years ago. Square tube bottom, 4 large casters, 3X3 rear upright with a gear reduction rotator on it! It will hold a Cummins NTC 350 with no problem - been-there-done-that.
It's holding a BB right now and isn't breaking a sweat! Paid under $100.oo at auction - they sold for $300~400 new. One of the best shop investments I ever made.
My worse is a cheapy 'Speed-Shops' (remember them!) special. Think it cost @$20.oo - and it works and looks like it. It drooped with my daughter's 1.5L 4-popper on it. I use it to hold bare blocks while I clean and paint them usually - then move the block to a better stand to assemble.
The others are pretty good bought or home builds that fill the need. They all have pivot retaining devices and if not square bases they have an added front cross-bar like the one in your link to held prevent tipping. Several have Chevy pattern mounts only (helps me get out of helping my wayward Furd friends ) and the others are adjustable.
Follow all the info givin in the other replies and buy the best one you can afford - then rent it to your friends when your not using it to regain your investment - worked for me! [img]graemlins/thumbsup.gif[/img]
Oh - and paint it "Chevy Orange" as soon as you get it!
1968 Convertible
Some trucks
Vintage 68 is offline
post #5 of 10 (permalink) Old Sep 6th, 03, 12:27 PM
Eric
How to judge quality when they're in a box - weight. Cheapos are made of light grade steel, better ones weigh a bit more . . .
I've had good luck with Sears brand personally.
Eric68 is offline
post #6 of 10 (permalink) Old Oct 24th, 03, 04:16 PM
Thumbs down
I stopped at Auto Zone today and checked out stands. Boy was I disappointed! They have a complete 305 engine on a stand up near the check out. Even the manager was a little skeptical with the strength of it. I kind of moved the motor and it started bouncing slightly and looked as it it could even break! The manager said that was the only one they stocked. I think it would have been a good one if you were just working on the block. The added weight of the heads, intake and carb made me nervous!
supv26 is offline
post #7 of 10 (permalink) Old Oct 25th, 03, 03:56 AM
Bill
Peter,
If you are willing to pay the price for a tool that will last a lifetime...check these out:
http://www.axeequipment.com/es40.htm
I think they are in the $350 range, but will hold a fullblown Marine 502 with a 6-78 Blower and all the water cooled exhaust on it...and not even flinch.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #8 of 10 (permalink) Old Oct 25th, 03, 10:53 AM
Angry
Boy, those two are beautiful Bill..
Way outta my price range but for the Pro motor builder or a guy flush with bucks, either one would be a great addition to a good shop.
pdq67
post #9 of 10 (permalink) Old Oct 26th, 03, 09:59 PM
I got a 1250# Chinese one from a local tool outlet for ~$70. It has a U-shaped (horizontal) lower frame that you can stand on when you're torquing head bolts. That way the stand doesn't try to move around. Might put a platform over it for a bar-stool too. Whatever you do, use good quality bolts to attach the engine. Grade 8 if possibe, no less than Grade 5.
jimfulco is offline
post #10 of 10 (permalink) Old Oct 27th, 03, 03:38 PM
I got two cheap ones- the ones with the three wheels and I just added a brace between the lower frame and upright part that holds engine and they have held up well over the years even with my big blocks on them
edd Gordon is offline
