Rebuilding a 700R4 - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 16th, 01, 04:26 PM Thread Starter
Would like to try and rebuild the 700R4 in a 84 Z28, with a shop manual. This is a first for me, any problems I might encounter? Special tools needed?
Robertlana is offline
post #2 of 2 (permalink) Old Jan 16th, 01, 04:40 PM
ok let me tell you that is NOT the tranny you want to rebuild for your first time i tryed what a nightmare in that trany there are 3 sections rebuild 1 at a time do not take it all apart you will go crazy you will need snap ring plyors also a pistion compresser and a press make sure you soak all the new clutches in new tranny fluid before you put it together and clean the tranny housing very good and do it in a nice clean place its not easy GOOD LUCK hope it works out
James
james is offline
