Oil pressure Tops at 50psi - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 24th, 04, 11:41 AM Thread Starter
I just got 200 miles on my 454 motor with edelbrock alum heads. I have about 20 psi at idle 800rpm. Then at about 3000 rpm oil psi tops at 50 psi then doesn't move until 5000 and above. and get this, starts to drop. I get scared and let go on gas. Any ideas please help.
Thanks.
P.s I have a stock oil pan and check oil level...
bikt_2000 is offline
post #2 of 10 (permalink) Old Apr 25th, 04, 03:08 PM
a67
Sounds like the oil pump pickup is too close to the bottom of the pan. Try a thinner oil and see if it continues to rise and does not drop off after 5,000 RPM.
Bob.
a67 is offline
post #3 of 10 (permalink) Old Apr 25th, 04, 03:52 PM Thread Starter
Found oil spilling out from my dipstick tube by the oil pan at 5000K. Starts to leak then oil pressure starts to fulctate. Need help
post #4 of 10 (permalink) Old Apr 25th, 04, 04:33 PM
Jody
camcojb's Avatar
Are you running a hi-volume oil pump?
Jody
camcojb is offline
post #5 of 10 (permalink) Old Apr 25th, 04, 05:30 PM Thread Starter
Yes, melling high volume, not high pressure oil pump.
post #6 of 10 (permalink) Old Apr 26th, 04, 03:15 PM
If you plan to hit 5000 on a regular basis a windage tray is in order. Could be that the oil is starting to foam up, hitting the crank (make it worse) and being blown out the dipstick tube.
dnult is offline
post #7 of 10 (permalink) Old Apr 26th, 04, 03:22 PM Thread Starter
I was thinking to do a leak down test, anyone think its worth doing it???
post #8 of 10 (permalink) Old Apr 26th, 04, 06:06 PM
Carl
Do you have a breather system, PCV, etc?
CarlC is offline
post #9 of 10 (permalink) Old Apr 26th, 04, 06:14 PM Thread Starter
Yea, pCV on the pass side and a breather on driver. Someone from melling told me I have to run a closed system, so no breather just a oil cap.
post #10 of 10 (permalink) Old Apr 26th, 04, 07:02 PM
Jody
camcojb's Avatar
A high volume pump really needs a higher volume oil pan. My guess is that at 5000 rpm you're pumping the pan dry (not literally but close).
Jody
camcojb is offline
