69 - 427 What engine codes? - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 2nd, 03, 06:53 PM Thread Starter
Hi,
What engine (block) code would I expect to see on a 1969 camaro "numbers matching" (other than the vin)427 Yenko motor?
Rich
rich pern is offline
post #2 of 7 (permalink) Old Aug 4th, 03, 05:17 AM
Russ
rafbody's Avatar
The engine casting number should be 3963512 for the cast iron 427 ci 425 hp. On the stamp pad in front of the passenger side head should have the assenbly plant code, date and a code of MN for a 4 speed or MO for an automatic.
Russ
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
rafbody is offline
post #3 of 7 (permalink) Old Aug 4th, 03, 08:19 AM Thread Starter
Talking
Hi Russ,
Thanks. The engine is supposed to be out of a 69 Yenko 4spd that was totalled in S. Carolina.
Hey, it's on the intenet so it's gotta be true right? Does that number determine that it was out of a yenko, or just a 69 cast iron block?
Thanks for all of the help.
Rich
post #4 of 7 (permalink) Old Aug 4th, 03, 08:46 AM
Those numbers just tell you it's an L72 iron block 427 engine. GM stuffed roughly 1000 of them into Camaros in 69, of those there are roughly 200 Yenko's. There are probably another 1000 or so originally in Chevelles as well. I would assume the engine has a VIN on it starting with 19N5xxxxx or 19N6xxxxx. Anything else and it's not out of a Camaro.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #5 of 7 (permalink) Old Aug 4th, 03, 02:19 PM Thread Starter
Thanks Mark!
Rich
post #6 of 7 (permalink) Old Aug 5th, 03, 08:58 AM
Russ
rafbody's Avatar
Rich,
If you go to copo.com you can look at partial vin numbers. I have a block that appears to be out of a Berger car. It is V0512MN stamp and the Vin is down by the oil filter.
Russ
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
rafbody is offline
post #7 of 7 (permalink) Old Aug 5th, 03, 04:52 PM Thread Starter
Thanks Russ. I did not know about CoPo.com.
I just got an offer to buy a 67 Vette 427 from a local guy, complete and running for $2200.00. He is putting a zz502 in his vette (not to smart if you ask me). I am still waiting on the numbers to verify the yenko engine and will keep you guys updated if he comes through.
Rich
