Valve Spring Question - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 15th, 04, 10:50 AM Thread Starter
Let's say I had a head that was to fit a 1.550'' valve spring, but the valve springs I need are 1.46'' would they still fit?
Drag67Camaro is offline
post #2 of 2 (permalink) Old Oct 15th, 04, 01:56 PM
Bill
Drag,
I would try to find a 1.550 spring that will give the proper spring pressures you need. The main reason is if the heads are cut for 1.550 springs, there will be nothing to keep the smaller diameter spring from walking around, unless you use a spring cup, and then you will lose some installed hgt. Take a look at the specs of the required spring and then go searching all the different manufacturers site. You should be able to find something that will work.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
