What exactly are TRW Forged pistons - Team Camaro Tech
post #1 of 10 (permalink) Old Jul 23rd, 03, 06:41 PM Thread Starter
What are these and how are they any different from any other type of pistons
[ 07-24-2003, 12:59 AM: Message edited by: garfield ]
garfield is offline
post #2 of 10 (permalink) Old Jul 23rd, 03, 07:13 PM
Why, they are a forged piston made by TRW (now federal mogul), of course Years ago if you wanted an affordable forged piston, TRW was about the only option.
travis is offline
post #3 of 10 (permalink) Old Jul 23rd, 03, 07:53 PM Thread Starter
How are they any better (different) from stock?
garfield is offline
post #4 of 10 (permalink) Old Jul 23rd, 03, 09:32 PM
SY1
The vast majority of GM pistons were cast. As far as forged pistons that GM used in high performance motors they were made by TRW and do not have the vertical ribs inside the skirts. TRW replacements have these. Supposedly they are stronger with the extra material. There are sometime other differences as well. For example 69 Z28 forged pistons carrying the part number 3927172. I have had several sets of these and have noticed differences in some of them. Ring land sizing and spacing, oil control hole diameter and number of holes have sometimes been different on some sets, even though they had the same GM part number. I've got one of the above part number pistons in front of me, it doesn't have the ribs, uses the larger ring sizes and larger, but fewer oil control holes. The reason I never used this piston is they did a poor job machining one side of the wrist pin retainer grooves. A good machine shop can fix that.
I said they are supposedly stronger because I purchased a set from Yunick's that Smokey had modified extensively. They were the GM part 3927172. I would think if there was a significant difference in strength he would have selected the TRW replacement over the GM part. With the amount of material he had removed from these pistons it doesn't appear strength is a big concern.
I've run both types of piston and haven't had a problem with either style.
[ 07-24-2003, 10:01 AM: Message edited by: SY1 ]
SY1 is offline
post #5 of 10 (permalink) Old Jul 23rd, 03, 10:59 PM Thread Starter
Oh, Thanks [img]graemlins/thumbsup.gif[/img]
When you buy an American car, you provide work for a man and his family for three months. -Jay Leno
garfield is offline
post #6 of 10 (permalink) Old Jul 23rd, 03, 11:26 PM
They are heavy. That is why Smokey milled so much off of them. Strong but heavy. I milled mine down to get the C/R where I wanted it and they ended up being slighly less wt than a stock TRW slug.
-Mark.
stingr69 is offline
post #7 of 10 (permalink) Old Jul 24th, 03, 01:47 AM
Send a message via AIM to Spames
I thought cast meant cast in a mold (like jello), and forged meant forged, like taking a piece of metal and pounding it into shape
Spames is offline
post #8 of 10 (permalink) Old Jul 24th, 03, 08:05 AM
SY1
Mark you're probably right on the weight. It is kind of scary though how much material he removed. The pads below the wrist pin bores were gone. It's a straight line across the base of the piston, the skirts were intact though. It's surprising to see how little material was left below the wrist pin bores.
"..............what, and get out of aviation??"
SY1 is offline
post #9 of 10 (permalink) Old Jul 24th, 03, 04:50 PM
Smile
Spames,
You have it just about right except they hydraulically warm press a slug to make them so they flow better instead of hot hammer forge them like a hunk of steel.
As for cast, I think they still do sand cast some pistons as well as use permenant free flowing molds and die cast like pressure cast again in permenant molds.
It's the silicon content of the metal that still confuses people...
Like hypo-eutectic, or below the eutectic point, eutectic or at the mix point where the metal upon setting won't lose any silicon alloy due to extra silicon grain growth and hyper-eutectic or over the saturation point of metal such that too much is in the aluminum so that it has to be mixed to keep it in suspension and when cooled makes a fine silicon grained wear matrix sorta thing...
pdq67
post #10 of 10 (permalink) Old Jul 25th, 03, 01:51 AM
That makes sense to me!
Spames is offline
