Powerglide tech guys - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 11th, 01, 10:25 PM Thread Starter
uhhh, how can you tell which powerglide has the different ratios in it. Like from the exterior of the tranny, can you get a casting number or something to identify which ratio it is. Thanks
CORNHOLIO is offline
post #2 of 10 (permalink) Old Mar 12th, 01, 04:39 AM
I may be wrong, but I was under the impression that all the glides came with the same first gear. When you get one aftermarket, you can then get a lower first gear.
Again, I am not possitive.
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Member of the "unwanted" 3rd Gen group.
Mark W. Winning is offline
post #3 of 10 (permalink) Old Mar 12th, 01, 04:48 AM
I have heard that the ones that came behind the 6 cylinder engines are the ones that got the higher first gear ratio.
boodlefoof is offline
post #4 of 10 (permalink) Old Mar 12th, 01, 07:56 AM
6 cyl and some low HP 283 powerglides had a 1.82 first gear and higher HP v8 powerglides had a 1.76 first gear. The 1.76 is more desirable because the planetary gears are much stronger. I don't know any way to tell them apart externally.
Stephen
[This message has been edited by squarles (edited 03-12-2001).]
squarles is offline
post #5 of 10 (permalink) Old Mar 12th, 01, 05:50 PM Thread Starter
huh, thanks alot. That helps some, so if its behind a 327 chances are good that it has 1.76. I would like to find a way from finding out from the outside, cause most of them at the junkyard have been pulled off already.
post #6 of 10 (permalink) Old Mar 12th, 01, 08:14 PM
Dale
There is a difference in the input shaft.I dont remember what it is though.If the trans is out,just pull out the shaft.Seems like the sealing rings are moved a little bit?
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #7 of 10 (permalink) Old Mar 14th, 01, 01:36 PM
Talking
My name is CORNHOLIO I need tp for my bunhole
Sorry guys had to do it....LOL
Jeff
RODKNOCKER is offline
post #8 of 10 (permalink) Old Mar 15th, 01, 11:12 AM
Jeff
Ditch the Pg and go with a TH350. That extra gear makes a big difference. I've got one sitting in my garage with a converter for $100. It will need new seals since it has been sitting for 6+ years. You'll alson need one of the conversion kits for the console shifter if that's what you have.
Jeff H is offline
post #9 of 10 (permalink) Old Mar 15th, 01, 04:29 PM
Robert
I'm with the rest of the guys. Have only heard of a aftermarket ratio.
Hope your using it on the strip or keeping your car original, beyond that I couldn't imagine why you'd want one. Switched mine out for a 700r4 felt like I added a 100hp (I could actually lite up the tires). Got used to that feeling so now I really do need more hp. Kinda like a drug, aint it.
Robert
'69 getting better every day... (every pay day)
rojo is offline
post #10 of 10 (permalink) Old Mar 15th, 01, 07:20 PM Thread Starter
I was just looking for them cause there is some guys that will pay bucks for them, if I can find some with 1.76 ratio's.
I guess they are getting hard to find, by the way that guy talks. And just to know for personal knowledge, I am a manual trans kind of guy myself.
