Vortec 350 Information - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 10th, 03, 05:08 AM Thread Starter
I'm not having any luck finding the specs on my stock vortec 5.7L engine that came from a '96 Silverado. What I need are the stock cam specs and the stock piston to valve clearance so that I'll know how much lift I can go with on an aftermarket cam without having to worry about clearance issues. Any suggestions on where I could find this information ? Thanks, Ron.
Rons68 is offline
post #2 of 2 (permalink) Old Sep 15th, 03, 07:23 AM Thread Starter
I found some information on the 5.7L Vortec engine, and I wanted to post it in case someone needs it in the future.
The stock cam specs are: Intake - 202 duration / .410 lift; Exhaust 207 duration / .424 lift with 115 deg lobe separation. The compression ratio is 9.4:1
Rons68 is offline
