Air Gap - Team Camaro Tech
post #1 of 2 (permalink) Old May 3rd, 04, 11:51 AM Thread Starter
I am in the process of putting all my accessorarys back on my new motor. I have the Air Gap intake on their now and I have run into a sang. My alternator bracket that connescts to the thermostat housing and the water pump won't fit any more. Because the AIrgap is so tall it raises the bracket high enough so that I can not bolt it into the water pump where it is supposed to attach. Have any of you guys run into this problem?? What did you do to fix this?
69 Camaro RS, 383ci,10.5-1 AFR 195's ported, Comp 286HR, 4340 forged Crank & Rods, JE Pistons, RPM Airgap, Holley 750 HP carb, 350 turbo w/ shift kit, 3000 Coan, Be cool, caltracs,12bolt 355 eaton posi..Best E.T. 12.22 @ 112
69CamaroRacer is offline
post #2 of 2 (permalink) Old May 3rd, 04, 11:55 AM
ZZ_430's Avatar
This works great.
http://store.summitracing.com/partde...rt=MCH%2D20120
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
