Yet another cam question - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 8th, 04, 02:05 PM Thread Starter
We are getting ready to assemble a 402 BB for my brothers 68 Conv. Camaro 4 spd. Planning on using a Lunati 00026 cam. I was wondering how this cam will be. Will it run brakes? I think about 10.25 to 1 comp. I got the cam cheap, but if it's going to be a PITA, I'll go with something else. This car will be a street playtoy, probally no track time. Any opinions???
hgerrick is offline
post #2 of 4 (permalink) Old Sep 8th, 04, 02:28 PM
I checked the specs on this cam and it doesn't look too wild for a street car. It's going to be a little lumpy at idle (personally I like this), but I put a hydraulic roller cam with more duration in my friend's 69 Chevelle and the power brakes still work fine.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 4 (permalink) Old Sep 8th, 04, 02:47 PM
Please consider a good old Isky 280 Mega cam on 108 LCA.
280/232, 108, .565" lift!
And if a little smoother idle is wanted, then get the same cam on 110 LCA that they also sell.
I figure both are ground straight up so you have to set the ICA at installation time if not mistaken??
pdq67
post #4 of 4 (permalink) Old Sep 8th, 04, 07:40 PM Thread Starter
Thanks for thr replies! The machinist thinks the cam will be ok, looks like we'll go for it. I think my brother will like the lumpy idle, I was a little concerned about the vacuum for the brakes.
Thanks again!
hgerrick is offline
