timing chain cover w/markings - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 25th, 03, 05:29 PM Thread Starter
toy
help i have a 1968 327 out of a camaro its new home is a rock crawling 79 toyota would someone anyone please email me a picture of a factory timing chain cover with timing marks on it the after market cover i have has none and the auto parts store bolt on piece doesnt line up i need a visual to look at to determine where the timing marks are located on the t/c cover i know i dont own a camaro but at least my motor is from one help please
toy is offline
post #2 of 3 (permalink) Old Sep 26th, 03, 12:29 AM
if your marks don't line up, make a new set that do. all you need is a piston stop of some sort. screw it into the spark plug hole, and turn the engine over until it gently hits the stop. make a mark on the balancer that lines up with the TDC mark on your current pointer. then go the other way until it stops and make a mark there, and right in the middle of that is true TDC. use a sharpie or an engraver or something and make an easily readable mark on the balancer, and use that to time the thing like normal.
you don't plan sincerity.
novaderrik is offline
post #3 of 3 (permalink) Old Sep 26th, 03, 03:36 AM
Angry
There are different bolt on timing tabs due to different balancer diameters. Make sure you have the right one. Many Chevrolet dealers carry these. You should check TDC, to make sure its correct.
TJS69 is offline
