engine help - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 8th, 05, 09:03 AM Thread Starter
i just replaced my intake,carb an it started back up but runs realy rough motor is shaking pretty bad but not back firing could i be off alittle on the dis, checked the rotor it looks to be pointing at the #1 cylinder any help ??
spazzz68 is offline
post #2 of 3 (permalink) Old Jan 8th, 05, 10:29 AM
Double check the plug wires...make sure you didn't flip flop a couple of them (its easy to do). Recheck the intake and carb bolts too and make sure they are tight. Also make sure all your vacuum ports are either plugged or connected to something. Have you rechecked your initial timing? Just looking at the rotor may get you in the ballpark, but you really need to set it with a timing light.
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #3 of 3 (permalink) Old Jan 8th, 05, 03:29 PM
Almost every thing you just did can cause the problem,like travis said first check firing order.Make sure there are no vacume leaks,time it with a light.How did you seal the front and rear of the intake? Could be a vacume leak there.
georgia 69 is offline
