What am I missing? - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 16th, 05, 05:08 AM Thread Starter
Dan
I was looking at the front of the block below the alternator. Though one of the unused tapped holes in the block I can see the push rod for the fuel pump. Surely oil will come out here. What sould be bolted here? What is missing?
DanBnis is offline
post #2 of 3 (permalink) Old Jan 16th, 05, 05:35 AM
hi there dan, yes you can be guarenteed oil will come out of there you need to put a short half inch long 3/8 bolt in place use a little thread sealer or rtv on it and you will be fine, from the school of hard knocks goodluck regards tom
Tom Goldberg
tman is offline
post #3 of 3 (permalink) Old Jan 16th, 05, 05:36 AM
Jody
camcojb's Avatar
Put a short 3/8-16 bolt in there to plug the hole. Oil will come out. Only needs to be 1/2" 3/4" long, you do NOT want it to hit the fuel pump pushrod!
Jody
camcojb is offline
