94 LT-1 in an 69 camaro - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 12th, 04, 12:54 PM Thread Starter
I am sure I am going to have a lot of questions about my swapping out a 6cly with a LT-1 and matching 4l60e. My main one is do you have to put the pump in the tank? I have been told if it is not in the tank you will have stall out and pressure drop problems. I have seen where a baffle was inserted into the tank to prevent fuel sloshing away from the pick-up tube .any and all suggestions appreciated.
Steve Bowden
Rochester Il.
P.S.
Where was the rotisserie plans located on the site I recieved a few plans in e-mails from a few on this site and it was appreciated but my computer crashed a few weeks ago and I lost everything.
tinner98 is offline
post #2 of 2 (permalink) Old Sep 12th, 04, 01:59 PM
Codi's Avatar
Done a few at www.rickroush.com. Transplant LT and LS 1&6 in tri-5 Chevy's. Also build/modify the frames for C-4 and C-5 suspensions. It can be fun. We have done both, pump in the tank and pump alomg the framerail. Never had a problem with the pump along the rail, however, the tank was bafled for this so the pickup is not uncovered.
Daddy's Hot Rod.
Codi is offline
