Fuel line for Quadrajet - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 12th, 04, 09:06 AM Thread Starter
Guillaume
Hello
I had a problem while taking my quadrajet out, I had to cut the fuel line because i didn't managed to unscrew the line on the carburetor side.
I see that summit sells a kit to replace the fuel line between the pump and the carburetor but i don't know if it will fit:
SUM-CARBKIT1
My carburetor is an original Rochester quadrajet from 67 and the fuel line as the same ends on both side: pump and careburetor but on summit kit there are two different ends.
Thank you for your help
Guillaume
gui67 is offline
post #2 of 3 (permalink) Old Oct 12th, 04, 10:02 AM
Vintage 68's Avatar
The "correct" type solid steel formed fuel lines are available from the restoration suppliers such as 'Ground-Up' (sponsor - link at bottom of page).
The line will be 5/16" or 3/8" depending on your engine type.
These lines are preformed to fit like the originals.
I would not recommend you try to use a "Universal" type line as it may hit or rub in places and lead to failure. Trying to bend preformed hard steel lines can lead to cracks and leaks.
Hope this helps;
ps; where in France are you? I go to the Grenoble area a couple times a year.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Oct 14th, 04, 08:51 AM Thread Starter
Guillaume
Thank you for your answer.
I found someone who does custom oil or fuel lines.
I think i will ask him a custom one, it will be cheaper then to buy one in the US and let it come here. (I hope there won't be any leaks)
I am from Strasbourg near the German border.
If never you come there, send me a mail and i will show you my car.
Guillaume
gui67 is offline
