Oil loss..........help!!!!!!! - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 27th, 03, 05:12 PM Thread Starter
I have a problem with my 95 Chevy truck. It has the 350 with the tbi. I am either using or losing oil. I belive that losing is more of the key. It seems to be around the rear of the engine, possibly the rear of the intake, or the oil sending unit. Have any of you bowtie fans been down this road with this engine? Are they notorious for anything like this? I'm not rear sure if it is one or the other or both. The truck has been well taken care of its whole life, and it has 84000 miles, but uses/loses approximately a quart every 1000 miles. I just thought if anyone has had a similar problem with a similar experience, they might be willing to share. thanks for any imput....
Jeff
bowtieusa is offline
post #2 of 6 (permalink) Old Mar 27th, 03, 07:00 PM
We have had a few 350s around that year in our shop with leaks at the rear of the intake,across the lifter valley.I would check the pcv system for blockage or a bad pcv valve when repairing,any oil leak. Good luck. [img]graemlins/hurray.gif[/img]
69 Camaro SS 350 4 speed<br />65 C-10 P/U All 93 Drivetrain<br />88 Ranger Pro Street Chevy Powered
gene stills is offline
post #3 of 6 (permalink) Old Mar 28th, 03, 08:03 PM
David Pozzi
davidpozzi's Avatar
Check the oil gage sender and intake seals. Both cause leaks.
davidpozzi is offline
post #4 of 6 (permalink) Old Mar 29th, 03, 04:48 PM
Bob
Mine does the same thing, 1995 K2500 HD with 350 and tbi. I only have 64000 miles on it. it has done it for a while and I just add oil. I can't be bothered taking it apart until it gets worse. It seems to always be about a quart every 1200-1500 miles. The engine burns no oil and it doesn't leave a mess on the floor. it does drip a little once in a while but it is a mess under the engine below the rear main. I have better things to do than worry about 2-3 qts between changes, but I do hate oil leaks. If I was to take the intake off, I would replce the heads and intake with vortec. I think the truck is kind of a dog.
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
post #5 of 6 (permalink) Old Mar 30th, 03, 10:09 AM
rear of intake would be the most common problem for that engine. and yes, the 95 350 engine was a dog- no power- David
67 RS marina blue, 406 ,M20 4spd, 9". car has been in my family since new!
67FREAK is offline
post #6 of 6 (permalink) Old Apr 1st, 03, 06:37 AM
robert
rolling-robert's Avatar
just dont put anymore oil in it, then it will stop leaking by it self.
J/K.
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
