code 32 and 33 - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 4th, 03, 09:51 AM Thread Starter
Hello,
My car is a 91 rs with a 3.1
The problem i am having is the motor will not take full throttle. It will idle and move but only to about half throttle. When jumping the terminals, i got a code 32 and 33. I believe these are MAP sensor and EGR. I replaced the EGR once before, little over a year ago. Does this sound like a bad EGR? I am not sure exactly what the MAP sensor does. (something with manifold pressure) Any suggestions are greatly appreciated.
Thanks,
Jack
jack91rsv6 is offline
post #2 of 2 (permalink) Old Apr 4th, 03, 04:53 PM
MAP sensor produces low voltage when the intake manifold vacuum is high, and higher voltage when the intake vacuum is low. If the MAP is bad, it can affect how much fuel is delivered to the injectors. If the MAP were to send a low voltage to the ECM all the time, it would be too lean at more throttle opening. I am trying to remember on that motor how the MAP is connected to the intake, as in a hose or what? It has been around 6 or 7 years since I had the fun of being a tech and having to bust my knuckles on cars at a dealership! I know the 4.3's were notorious for EGR troubles though. Try to find a buddy with a scan tool, and see if you can check the MAP voltage, and EGR operation too.
Oldani Motorsports
Oldani Motorsports is offline
