power steering bracket - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 30th, 04, 01:16 PM Thread Starter
Rob
What should I do?I'm having trouble with my back power steering pump bracket.Not the one that bolts to the block by the harmonic balancer,but the one that bolts on by the motor mount,I have a 68 sbc 327ci.My motor mounts are from National Parts Dopot, part # C-0027-2A,I was told to get these on this wep site.My problem is I can't get the bracket under or over the mount.Should I modify these pieces so they go together?,or is there a corect bracket I could buy?Thanks for any help.
PAWS 67
roberttalsma is offline
post #2 of 4 (permalink) Old Oct 4th, 04, 06:48 PM
Here's a pic of what you need and check out this forum link. Do a search in Engine also.
https://www.camaros.net/forum/ultimat...41.html#000002
1967 Camaro coupe Deluxe interior LT-1 350 w/ 4spd. M-21 trans and 12 bolt rear.
RamJam is offline
post #3 of 4 (permalink) Old Oct 4th, 04, 07:45 PM
Jack
I cut off a small piece of my P/S bracket so it would fit. I suspect you have the same mount. Take the engine mount off and mate the bracket up. You will see the problem. Took about 5 minutes with the dremel to fix.
67 RS
Royal Plum/Parchment
6.0 LSX 4L80e
06 corvette Z06
machine silver
jackr is offline
post #4 of 4 (permalink) Old Oct 9th, 04, 10:57 AM Thread Starter
Rob
Angry
Thank's for the replies.Yes I did order and recieve that kit from"D&R" It works fine.Mission accomplished! [img]graemlins/beers.gif[/img]
PAWS 67
