distributor selection - Team Camaro Tech
post #1 of 10 (permalink) Old Sep 10th, 03, 11:11 AM Thread Starter
im putting together a 350. and putting it in my 69 camaro. im looking into dist. the chevy hei looks good but the book says you need to beat on the firewall to get it in. does chevy make a eletronic dist that fits or does anyone recommend anything better, ive been using mallory for a couple of years and im happy with it, but im always looking for improvements, (like everyone else.)
beattie z28 is offline
post #2 of 10 (permalink) Old Sep 10th, 03, 12:30 PM
What book says you have to beat in the firewall??? I have an HEI in my 69 Z/RS and although it's close to the FW it fits fine. Sometimes when restos are done the frame is put back in the car too far back (not aligning the frame holes with the body), or if the car gets hit at the front, the frame gets pushed back a little. If your car hasn't been hit or taken apart and put back together improperly, the HEI should fit. Check mine out in the link.
GMJim is offline
post #3 of 10 (permalink) Old Sep 10th, 03, 01:25 PM Thread Starter
gm parts and ricks 1 gen. what radiator do you have? and what did you d about a fan? thatis one nice resto. beautiful job!!!
post #4 of 10 (permalink) Old Sep 10th, 03, 02:30 PM
http://www.davessmallbodyheis.com/
Dave can convert your existing points distributor into an hei unit. It will look stock, use the same cap and rotor, only it will have an hei module installed.
Dave knows his stuff! Plus he will curve the distributor for your engine.
Hoptup32 is offline
post #5 of 10 (permalink) Old Sep 10th, 03, 06:07 PM
I've got a GM HEI in my 69, fits no problem
http://www.cardomain.com/id/69huggrrr
<a href="
target="_blank">
href="
target="_blank">http://www.ontariocamaroclub.com/</a>
69Huggrrr is offline
post #6 of 10 (permalink) Old Sep 10th, 03, 06:08 PM
<a href="
target="_blank">
href="
post #7 of 10 (permalink) Old Sep 10th, 03, 06:26 PM
A second recommendation for Dave's small body heis. I've got a couple of photos if your interested.
-dnult
dnult is offline
post #8 of 10 (permalink) Old Sep 11th, 03, 01:07 PM Thread Starter
called dave, got one in the works. thanks for the recommendation
post #9 of 10 (permalink) Old Sep 13th, 03, 12:02 PM
Bob
I don't know why so many people have trouble putting HEIs in 69 Camaros.I have a Mallory 9000 with a huge top on it and I have plenty of room to the firewall, I would say about 3/4 of an inch. I have a big block, are small blocks tighter to the firewall?
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
post #10 of 10 (permalink) Old Sep 14th, 03, 02:55 PM
Unhappy
It all seems to be a matter of what engine, frame mounts you have. If your HEI fits easily, chances are your headers will hit the steering box and you may have trouble with an 8" balancer. My situation was no problem with headers, but I HAD to dent my firewall some for my HEI.
TJS69 is offline
