81 z28 big block conversion - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 18th, 04, 11:52 PM Thread Starter
I have a 81 Z with no motor and I have a 78 chev van with a 454 ,I want to install it .I have done it before with a trans am . I am curious about the motor mounts and the exaust manifolds ,pulling the mounts was ****ty on the t.a. not loooking forward to that again .and I am not sure about the pipe connecting to the manifold ,is it different then the small block .I think on the t.a. I used ones off a 78 half ton .but not sure was about 10 years ago .Any way got a great deal on the motor and car .will sure be happy to get it together .Also have a 74 vega with the can am package on it .
lunk is offline
post #2 of 6 (permalink) Old Apr 19th, 04, 07:49 AM
The small block frame mounts work fine and allow for 2.25 inch headers with minimal clearancing. This is for a car without AC.
Jim McGregor is offline
post #3 of 6 (permalink) Old Apr 20th, 04, 05:46 AM
Bill
You will probably run into hood clearance issues with any intake other than the LS5 or Torker II.
WildBillyT is offline
post #4 of 6 (permalink) Old Apr 20th, 04, 05:54 AM
WildBill is correct. I had to use a cowl hood to clear the Team G manifold and Demon carb. Besides
a cowl hood looks pretty good on a second gen.
post #5 of 6 (permalink) Old Apr 20th, 04, 10:19 PM Thread Starter
Those are some really great tips thanks exatlywhat I was looking for
lunk is offline
post #6 of 6 (permalink) Old Apr 21st, 04, 06:07 AM
Bill
In addition, you can use the stock clamshell motor mounts.
