max lift with stock valve springs - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 25th, 01, 03:02 PM Thread Starter
Does anyone know what the maximum valve lift a small block chevy with stock valve springs (441 head castings) can use?
b-boy is offline
post #2 of 4 (permalink) Old Jul 25th, 01, 06:51 PM
490 lift bud , thats the most u can go i ran mine for 1/2 a year with stock valve springs with a 480 to 490 lift comp cam and had no probs until we added roller rockers which increased lift to about 500 then i broke one valve spring in to places , now i got 560 lift springs
camaro79tx is offline
post #3 of 4 (permalink) Old Jul 26th, 01, 06:17 AM
I'd follow the cam manufacturer's recommendations. Changing springs is cheaper and easier than broken parts.
Huck
355 SBC powered '87 Chrysler Conquest TSi - 10.3:1, Vortec heads, XE 268H cam, HEI, eq. length shorties, Performer RPM intake, 750 Edelbrock (1407), T-5 and 3.54:1 posi indep. rear
Huck is offline
post #4 of 4 (permalink) Old Jul 26th, 01, 07:10 AM
Huck has it right change them when you change the cam. If you have ever tested a stock spring that has some miles on it you wouldn't even consider using them with a performance cam.
oger is offline
