Alternator Help - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 3rd, 03, 02:03 PM Thread Starter
bowtie1Z28's Avatar
Having trouble with throwing my alternator belt at higher rpm's. I have work on pulley alignment and think I am pretty close but it still trhrows the belt so I thought I would put a larger diameter deep groove alternator pulley to see if that would help the problem. I bought a Moroso 5" pulley that is supposed to be for GM/F**D alternators and the problem is after you install the factory spacer and fan and then the new pulley you it winds up flush with the end of the shaft with 0 room for the nut. Called my local speed shop where I bought it and all he could tell me was they sell a ton of them but I would have to call Moroso tech for any more info. I am sure I am not the first to run into this so what gives?? What an I not seeing or is there some additional parts needed like and new fan?? Thought I would try here first since it is too late to reach the tech line out east today. It is a standard mid to late 70's GM 3 wire alternator with a built in regulator.
bowtie1Z28 is offline
post #2 of 5 (permalink) Old Sep 4th, 03, 08:14 AM Thread Starter
bowtie1Z28's Avatar
Nobody has run into this problem before??
post #3 of 5 (permalink) Old Sep 4th, 03, 08:20 AM
I used to run one of those. I have slept since then but it seems to me that I may have left the little wedding ring sized spacer out when I reasembled it. The pulley has a raised area that does the same job I beleve. Just something to try. I could be wrong
-Mark.
stingr69 is offline
post #4 of 5 (permalink) Old Sep 4th, 03, 02:31 PM Thread Starter
bowtie1Z28's Avatar
Hey Mark!
The Moroso tech guy said leave the spacer and the fan out if needed. The most important thing is that the pulley lines up with the WP and crank pulleys. The pulley does have a raised area that looks to me like it would do the trick except it is a larger diameter that the original spacer and won't fit in the recessed area on the front of the alternator. I have a friend that has a machine shop and may have him reduce the area on the pulley to match the OD of the original spacer or just completely remove this step and use the original spacer. I plan to take the alternator with all of the original pulley hardware and the new pulley along to his shop and will set it up to put the Moroso pulley in the right location. Thx for the reply!!!!
post #5 of 5 (permalink) Old Sep 4th, 03, 02:33 PM Thread Starter
bowtie1Z28's Avatar
Forgot to ask.......is it OK to run the alternator without the factory fan or could I experience some kind of overheating and damage to the alternator???
