Header Problems - Team Camaro Tech
post #1 of 5 (permalink) Old May 15th, 04, 06:08 AM Thread Starter
Send a message via AIM to orange77
Just wanting to know if anyone else out there is running Hooker Competition headers with Vortec heads. Mine don't work as well as they did on my Iron Eagle heads. I can't get the number 6 plug or wire off without pulling the whole header. [img]graemlins/clonk.gif[/img] Seems pretty poor to me. Anyone have the same problem? Also, can anyone recommend a better long tube header that is not overly expensive? Thanks.
Rob
1977 Camaro with a '96 Vortec and a few goodies<br />1992 Chevy 3/4 4x4 with a weak 305
orange77 is offline
post #2 of 5 (permalink) Old May 25th, 04, 09:10 PM Thread Starter
Anyone? Anyone at all?
orange77 is offline
post #3 of 5 (permalink) Old May 26th, 04, 08:09 AM
Eric
I don't run Vortecs or Hooker headers, but my friend ran the Hookers on his 327 with Iron Eagles and had the same problem.
We changed the heads and went with ProTopline straight plug heads and had the same problem with #3 and #5 not clearing the Hookers. So he dumped the Hookers and went with the Hedman Elites and plug clearance is much better, but its still a little tight for cylinders 5 and 6.
I run the Hedmans on my engine with angle plug TFS 23* heads and they fit great.
My point is that the Hedman elites seem to work really well with angle plug heads and OK with straight plug heads. Hookers seem to be a PITA regardless of what head you are running.
Just my personal experience.
Eric68 is offline
post #4 of 5 (permalink) Old May 26th, 04, 10:14 AM
Send a message via MSN to kausboy
I am running Hookers on my car with Dart Iron Eagle straight plug heads and I am having the same problem! #6 & #3 are impossible to get a plug socket on! I dread the day I have to do a tune up!! If the plugs are real tough to break loose I think I will have to drop the header.
kausboy is offline
post #5 of 5 (permalink) Old May 26th, 04, 07:17 PM
I am running vortecs on my '78 chevy truck with a set of cheap flowtech full length headers...excellent plug and wire clearance and fit the chassis great. I know this isn't the same header application but may help somewhat.
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
