Older Vortech Heads? - Team Camaro Tech
post #1 of 9 (permalink) Old Oct 14th, 03, 07:10 AM Thread Starter
My engine shop has a set of "older "vortech heads, pre '96? that have been rebuilt. I want to put them on my 327. I am in need of an intake that will fit these. I have been told that the new Edelbock Vortech intake has a different bolt pattern, 8 holes vs 6. Was a different intake made for the first gen vortechs? Where could I find one to fit them ?
Help
thanks
1968 Camaro Z28 clone 327 .030 over, Muncie M20, DUI coil, Edelbrock Performer w/1406 , headers, 274 cam
1963 Chevy Biscayne-2 door, 283 2bbl, powerglide, Mallory Digital ignition
1985 Z-28 LG4, Edelbrock hdrs, Lakewood control arms
rusty Z is offline
post #2 of 9 (permalink) Old Oct 14th, 03, 03:31 PM
Matt Jones
Vortec heads were ONLY '96 and up...but there were heads made in the early 90's that had a boss casted in the intake bowl that helped the air/fuel 'swirl'. These will kill any power above 3000RPM, but help make good torque.
I would skip on those heads and find others...I'm pretty sure you wouldn't be happy with them.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #3 of 9 (permalink) Old Oct 15th, 03, 03:41 AM Thread Starter
These heads do have the center bolt valve cover boss. Does that mean they are simply early 90's GM heads from a TBI motor? I'll check for the boss on the bottom side too.
rusty Z is offline
post #4 of 9 (permalink) Old Oct 15th, 03, 04:57 PM
Matt Jones
Centerbolt valve covers were used on all passenger car applications starting in 1987, I think.
post #5 of 9 (permalink) Old Oct 15th, 03, 05:26 PM
the intake u need is edelbrock #2104.....i have the same heads on my engine that came out of an 89 suburban,TBI....it does have center bolt valve covers but unlike the newer vortecs they do have center intake bolts which are canted
Nick
68 camaro, 350, comp cams xe262, hooker super comp headers, torque thrust II's, its a work in progress
NDubs68 is offline
post #6 of 9 (permalink) Old Oct 16th, 03, 03:35 AM Thread Starter
Angry
thanks for the feedback guys! I looked up the casting # yesterday for fun and found they are from a '87 up 350. Yeah the hardest part has been finding the right intake with canted center bolts! #2104 looks right. Have you guys had a good experience with these heads?
thanks
Matt [img]graemlins/thumbsup.gif[/img]
rusty Z is offline
post #7 of 9 (permalink) Old Oct 16th, 03, 05:02 AM
i have them on a freshly rebuilt engine with semi mild cam, intake, hooker super comp headers....and im satified witht he results. but i am going to upgrade just because im in the stage of my life where i need more power(im 17)
Nick
NDubs68 is offline
post #8 of 9 (permalink) Old Oct 16th, 03, 05:22 AM
Matt Jones
I would not purchase the heads, if you don't already have them. Consider getting a cam over 210* out the window, those heads just wont flow enough.
By the way, there was a Chevrolet Off-Road bulletin a while back that stated the center two bolt holes (per side) are not necessary. Install a pipe plug flush with the mounting surface to block oil leaks. I've seen a few guys do it, never seem to have any problems. This way you can use a standard intake. Something to think about anyway.
Matt Jones
post #9 of 9 (permalink) Old Oct 16th, 03, 05:28 AM Thread Starter
Unhappy
I already had the heads put on the motor! He finished it Monday. I checked the parts list he gave me and the cam reads as a CE 274. I don't know the other specs yet or the brand. I will get them when I pick up the motor. He put in @9.75 :1 pistons which I think will help. I told him I wanted @300 hp from it, we'll see! [img]graemlins/thumbsup.gif[/img]
rusty Z is offline
